    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    Door speaker size???
    is it 5.25", im replacing them with better jl ones but need to know what size the standard ones are
    thanks in advance for any help
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    You might want to re-post this in the ICE forum or PM AndyMac (a member on here) -what that man doesn't know about audi ICE isn't worth knowing.
    Jun 2003
    World of my own
    9,813
    Standard fronts are 4" mids and 1" tweeters. They're also mounted in a bizarre fashion with only 3 mounting posts offset from the aperture in the door card so you need adapter rings to mount anything in there (even an aftermarket 4" driver). Depth is the biggest problem as you only have about 60mm including the adapter rings.
    Nov 2005
    lothian
    181
    I bought some of these for mine 5.25s fitted ok with the fitment rings.
    http://www.caraudiodirect.co.uk/prod...25141edfa26020
    Fitment rings:
    http://www.caraudiodirect.co.uk/prod...roducts_id=479
    So 5.25 will fit but andymac is still right... the std ones are 4"
    killa_z's Avatar
    Couped Out
    Aug 2006
    London
    175
    thanks fellas,
