JMB RetrofitsAH Fabrications
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    high milage what engine parts need changing....
    Hi, just wondering what do you guys recommend replacing from the engine once the cars done over 80k, I have a new flywheel, cambelt, clutch, dv, airfilter. Anything else, I think i might need a new exhaust as its quite boomy at around 3k revs for some reason, maybe it has a hole?
    Also how long do the turbos last? and what other belts and parts are there to change?
    Thanks dudes
    Allan
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    Jul 2005
    2,488
    waterpump? shocks?
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    cool anything else, are these parts cheap and faily easy to fit yourself?
    Jul 2005
    2,488
    unfortunately the waterpump is usually done at the same time as the cambelt. You may as well get the cambelt, tensioners and waterpump done all as one, as it's mostly labour...
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    cambelt was done before i got car, its going on on tuesday to have some work done, sort out esp light on dash, bleed brakes and fit new pads. Plus i wanna get whatever else needs doing at the same time.
