EM TuningJMB Retrofits
Results 1 to 15 of 15
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    BMC Panel Filter (S3)
    Just sort of noticed these exsist, how do they rate against K & N ? Same thing i recon ? Also at less than 40quids i think their a bargin.
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Aug 2006
    NI
    785
    I cant imagine they make much odds mate.
    back to boost, oh how I missed thee....
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    All the panel filters are about the same really, cotton gauze or foam there just less restrictive.
    Built in Germany, Perfected in England
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quote Originally Posted by Randomjim
    I'd agree that they're all basically the same, but they're no less restrictive than the standard paper filter as long as it's changed regularly. They may give you a bit more induction noise.
    [/sarcasm]
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    go for one that isnt oiled, the k and n can damage the engine, the bmc is dry thats why i went for it, dont no if its made any difference cos only had the car a few days before i changed it.
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    Oct 2003
    South Wales
    2,942
    Another vote for the standard filter...
    Dolphin Grey Audi S3 8P
    PaulRS3's Avatar
    UK
    1,006
    stick with standard, change every 10K miles.
    Audi RS3
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quote Originally Posted by PaulS3
    stick with standard, change every 10 miles.
    Wow, that must be an expensive hassle for you Paul. I'd recommend every 10,000 miles
    [/sarcasm]
    PaulRS3's Avatar
    UK
    1,006
    Audi RS3
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    im thinking about this cant decide wether to change the currnet filter in the box for a K&n panel or should i go for something like a cone and remove the box altogether? Ive heard you actually loose power though doing this?
    What you think? Cone or replace panel filter?
    Jason
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by Jason_letts
    Yes you can loose power...when it's hot and the engine is drawing in hot air, you're loosing power over the standard airbox, when using a cone filter.
    A K&N in the standard airbox won't give you any more power either...
    The standard airbox is pretty good - good enough for 400BHP or so - and the standard filter isn't restrictive if clean...so why bother?
    Unless you want more noise / bling...then go for it.
    Cone filters can apparantly contribute to MAF failures...
    Never heard of a tie up between the panel filters and failed MAFs...
    Standard was good enough for me.
    If you must go aftermarket, then a BMC or similar is probably the better option as long as you can route the inlet hose to a cold feed...which isn't easy on an S3.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    My pipercross is fine, just spray a fine mist of oil and it'll be all good, and for 20quid cant grumble, i did notice the throttle response was a tad better tho. Hope that helps
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    a little off topic here but what's the benefit / drawbacks of oiling the panel filter - i've recently got a pipercross filter for my A3 but can't decide whether it's worth oiling or leaving it as standard and just wash it out regularly?
    hijack over
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    if u spray to much oil it will get suckked thru and onto the MAF, but like i said b4, just very little spray and let it dry out overnight and it'll be fine
    Nov 2005
    UK
    1,689
    i havent looked yet but is there any de-restriction with the airbox. I will probably go for a BMC filter seems good value.
    wanted for 8L S3:
    Milltek system
