JMB RetrofitsSky Insurance
    AUDI A3 1.8T Sport 51
    Aug 2006
    wimborne,Dorset
    MYSTERIOUS CLUNKING NOISE UPDATE
    when driving with any degree of lefthand turn, a random clunk clunk comes from the front centre left of the vehicle, it happends even more on rough and bumpy
    roads in forwards and reverse, but only with lefthand turn!.
    its only just had a mot and its been back to a garage and they cant find anything wrong with bushes and drive shafts
    what do you think fella's?
    UPDATE
    Its still doing the same, but ive noticed that when starting the engine the same noise sometimes occurs and its below the gear stick area.
    The noise is the same as the other i have heard,it sounds like a hollow clunk, like
    something isnt solid, i would be grateful for any advice
    Thanks for your previous replys
    Aldo's Avatar
    Jun 2006
    1,004
    Balljoint?
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Track rod end, mine went and did the same thing!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    S3 YEA's Avatar
    Sep 2006
    34
    Quote Originally Posted by JamS3
    Agree. Its probably this. Could also be a suspension bush. I suspect it won't be dangerous, but it'll be one of those things that you should probably sort now else it'll get worse and could become dangerous or cause probles with your tyres wearing unevenly.
    Burnin' the clutch
    Aug 2006
    Same problem
    I recently had the same problem on my clio sport not my a3. However, ppl where sayin it my be the bushes etc.. Belive it or not, it was my caliper! It was loose! worth a look!
    MIKEY
    Aug 2006
    wimborne,Dorset
    its not the track rod end, i havent checked for a loose caliper, but i will
