rraghvani said:
I'll invest in Ferodo DS2500 then. How easy would it be to do brake bleeding? Will I have to consider stuff like power steering, abs and engine on/off?
As long as you've not had the callipers off the car, or changed the hoses, you'll not need to consider the ABS unit as it's unlikely you have air in there...so the engine on/off doesn't matter.
You don't need to consider ARBs or PS anyway when bleeding brakes...
As for the actual bleeding...if you aren't fully up to speed, please consider having someone who is, do it for you.
Brakes are the last thing between you and something big and solid...and you really don't want to take chances with them.
A garage won't charge you much to flush the system through and bleed them...
I've been bleeding brakes for nearly 20 years...and still hate it...takes me a few attempt to get it right still.
My mechanic mate can do the full job, first time, in about 20 mins.
It's not worth my time and effort now...it's cheaper to buy him a few pints and get it right first time, every time.
It's just a thought...but a local garage won't charge you much to do it.
