AH FabricationsSky Insurance
Results 1 to 22 of 22
    Mar 2004
    95
    Question Petrol smell through vents when stationary
    Think this is a bit of an odd one but here goes.
    When the car is stationary or moving at very low speed I get what I can only describe as petrol fumes through the air vents (with aircon on or off). Has anyone else had this / know what might be the cause? I haven't keeled over yet but its a bit worrying!
    Jul 2006
    40
    Hi, I had a similar problem with a fuel smell on my A4. In my case I couldn't isolate where the smell was coming form, just that it was present when the car was stationary, not there once I got moving. Turned out to be a tiny crack in the fuel filter, which in the A4 is located on the underside below the driver's side rear passenger door. Called Audi Assist and it was a 20 minute job for them to replace it. Not sure where the fuel filter is located on the S3 but it might be a contender for your prob.
    Mar 2004
    95
    Thanks Cadders, its due a trip to the garage soon so will get them to check out the fuel filter. Glad someone else has had a similar issue. Cheers
    Audi_Alex's Avatar
    Apr 2008
    Milton Keynes
    57
    Hey there, sorry to bring up an old post, but it's relevant...
    I've got the same problem where I have an unburnt fuel smell coming in through the dashboard vents when stationary or moving at slow speeds. Do you think a leak from the fuel filter (near the rear of the car) can get the smell up round to the front of the car?
    Is there anywhere in the engine bay which is prone to leaking which could seem like an option? Injectors, regulator, fuel rail, return? I'll replace the fuel filter anyway as its a cheap component and easy to do, but I thought I'd get some opinions out there
    Cheers for reading!
    Alex
    2000 Audi S3
    grathies's Avatar
    More Points Than Portsmouth FC
    Dec 2004
    Portsmouth, Hampshire
    1,355
    I have had this, was told its to do with one of the small hoses that connects to/by the left hand side of the inlet manifold, think it might be the u shaped one
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    I got the same thing, havent done anything about it but probably will next time i take it in the garage!
    Agric04's Avatar
    Feb 2011
    Grantham, Lincolnshire
    198
    Hi I am completely new to forum posting.
    Sorry to hijack this old thread but was wondering if anyone found a conclusive solution to the problem which sounds the same as mine?
    I bought my first MK1 S3 a few weeks ago, 2001 Grey 210 AMK with 128,000m on the clock. First thing I did was get it to JabbaSport to fit a new thermostat as the car was running cold and fit a new breather pipe as it was split. I asked them to have a good check over the engine so I hope they have replaced all that needs replacing.
    I did think the new breather pipe would solve the fuel smell problem but it doesn't appear to have done. Like some of the other posts I get a fuel smell come through the vents when I come to a stand still, but not when the car is moving. This seems to be a common thread when I search google but there seems to be few resolved answers out there.
    If I lift the bonnet and have a sniff around there is a fairly strong smell of fuel coming from behind the engine just to the right of the turbo.
    Has anyone found any solutions or can share their experiences with this problem?
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    On my 1.8T AGU there is a box at the back of the left side of the engine bay, looking from the front of the car. There are 3 pipes that go into it which are fuel pipes, make sure that they are pushed in properly as mine cut out once and it was one of these pipes that had come off. I'd say that the S3 has this in the same place, also check the pipes themselves for cracks and also check the injector seals as well. If the outside of the injectors are wet then it will be the seals.
    Jul 2010
    111
    had this on my s3, it was one of the plastic pipes running to the carbon canister i beleive that was makind the smell, replaced it with silicone tubing and now its fine
    2001 S3 AMK. Viper Remap, Forge 007P, Carbon fibre engine cover, SFS TIP, Tints, Forge Breather Hoses, Auti R8 oil Cap, Leon CPR Top mounts, S3 car mats, German number plates. 249 By Pass mod
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by IOM-S3 View Post
    x2
    S3 finatic's Avatar
    Limp mode
    Feb 2011
    Norwich
    68
    Hi, any conclusion to this problem.
    I've had this problem since i've had the car, but it has'nt bothered me until i see this thread.
    I've only got that unburnt fuel smell coming in through the dashboard vents when stationary.
    Has anyone else experienced this problem, and managed to resolve it?
    Going to try all the other options at the weekend.
    Previously known as mark_sarah
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    I had this problem too on my old 2000 model S3. Audi traced it to a faulty breather pipe/hose (8.16) cost. It was replaced and never had any issues again. I have since sold that particular S3 so i can't look up the part number I'm afraid :-(
    Jul 2010
    111
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    same issue, fixed with like for like replacement from Audi as I read silicone & petrol are not good
    Agric04's Avatar
    Feb 2011
    198
    thanks for the responses and suggestions guys, will have to have a poke around the engine bay to see if I can see what might be causing it. Will post the solution as soon as I resolve it. Cheers
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    have a look at number 6
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    I seemed to have noticed this recently as well, I have changed my fuel regulator pipe with a silicon one as it had snapped off, do you think this could be the issue, all other pipes seem to be ok.
    Agric04's Avatar
    Feb 2011
    198
    Well I think I've found my issue, have found a big old hole in the induction pipe about half way down where another pipe joins into it. I'm guessing that when I come to a standstill the pipe isn't sucking so much so gas escapes from the pipe and makes its way into the vents. Just need to get a new pipe now and see if it solves my issues. Question is now should I get an OEM induction hose or a Forge silicone hose? Does anyone have any experience?
    I've attached a link to the images of my faulty pipe for those interested.
    Audi S3 pictures by ajbarbour - Photobucket
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You need a silicone tip, much better, or one step further with the 3" tip badger5 sells
    Agric04's Avatar
    Feb 2011
    198
    Thanks S3dave. I've just found a second hand oem induction pipe with the full set of associated pipework for 39 delivered on ebay, so this is going to be my cheapest option for now. Will have to look into silicone upgrades in the future. Going a bit off thread now but still connected if anyone else is suffering from bad condensation on the oil cap it maybe linked to the same broken pipe I have just found on my S3. the pipe that is broken on mine is the pipe that creates a vacuum to suck the gases out of the top of the engine and water vapour along with it, there is a plastic valve thing also attached to this pipe and mine was full of gunk presumably because I have no vacuum so it's built up. I'm sure someone on here may give a more accurate technical description of this and how it works.
    Tonight has been a good night looks like I may have solved my smelly vents and my problem with excess condensation in the engine in one hit. Hopefully this will also solve my lack of power as I think I'm lacking boost higher up the rev range, who knows maybe 3 birds with 1 stone tonight...fingers crossed.
    Image hosting, free photo sharing & video sharing at Photobucket
    Thanks for everyones help and suggestions.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Well you certainly would have got unmetered and unfiltered air in so that could be your running problems sorted too...well done
    Agric04's Avatar
    Feb 2011
    198
    I think I've inadvertantly broken my earlier link to the pictures of my faulty pipe so here's the pictures again:
