Monster MotorsportChris Nott
    74
    Problem with standard Chorus radio on my S3
    Not sure to be honest if this problem has always been with the car & I've not noticed.
    Though yesterday when I removed the keys from the ignition & the stereo went off though I noticed I could still turn the stereo on afterwards (the display is slightly dimmer though) , and even stranger close the doors & alarm it to find the stereo on ??.
    Any suggestions this must be a fault surely ?
    Nov 2004
    Northampton
    Re: Problem with standard Chorus radio on my S3
    Can someone help with my problem ??
    Radio is on with car running,
    turn engine off - remove key.
    Radio is still on ??
    Lock car and radio just stays on.
    The only way is to turn the radio off, every time i use it.
    Oct 2003
    South Wales
    2,942
    Once you have turned it off, can you turn it back on without the key in the ignition?
    Does this happen everytime you take the key out or is it intermittant?
    Jun 2003
    World of my own
    9,813
    Mr Ranger, what head unit is it?
    Some late model A3's do not have an ignition on feed to the head unit, but use the CAN-BUS to tell the HU when the ignition is on. Sounds to me like someone has fitted a different HU and either not bothered to wire it in correctly or is not compatible with CAN-BUS so has to have the ignition on wired to perm live.
    Either way it is relatively easy to wire in an ignition on from the fusebox. There's a thread on how to do this in ICE forum. Just run a wire from the Radio (S-Kont) fuse.
    Nov 2004
    Northampton
    Thanks for your replies, The head unit is the standard audi concert with 6 disk changer.
    Whilst driving today with the radio on, it just turned itself off without any reason.(after 1 hour)
    I seem to recall someone mentioning if your ignition is off you can put the radio on for 1 hour only.
    It would seem to me (not technical when it come so radios) that the power for the radio is coming for this one hour timer opposed to its normal feed when the car is running hence staying on when the ignition is removed. Maybe a dodgy relay???
