Volks AutosBadger5
Thread: Brakes
    hamski's Avatar
    Sep 2005
    UK
    116
    Brakes
    I do need some advice now. Replacement Movit discs for the front are gonna be cŁ500 for the pair, plus Ł125 for pads. The discs apparently are in two bits (is this a floating disc?). Does anyone know where I might find a cheaper replacement?
    Golf Mk2 16v
    RS4 Cab
    Middlesex
    142
    Recently looked into this as my movit setup needed new discs and pads although not actually got around to fitting it yet, QST price was a bit steep when I asked for a quote on replacements.
    I ordered 993TT discs and pads from http://www.design911.co.uk discs were about Ł160 each and textar pads Ł70ish.
    You need to remove the hat from the porsche disc and swap it over to your Movit hat before fitting.
    hamski's Avatar
    Sep 2005
    UK
    116
    Lovely, thanks
    Golf Mk2 16v
    RS4 Cab
    hamski's Avatar
    Sep 2005
    UK
    116
    How do you know which ones you need? Is it simply a matter of measuring them?
    Golf Mk2 16v
    RS4 Cab
    Middlesex
    142
    I checked what the system mine was based on, it uses 993TT calipers with the Mov'it logo machined into them on both sides so I bought 993TT discs to suit, should be 322x32mm.
    YX1010
    Sep 2006
    Auckland, New Zealand
    24
    Go for DBA slotted Rotors front and rear.
    This is what I have and i swear by them. I also do quite a bit of track racing and they dont warp like other performance slotted rotors and they have a kangaroo paw system which cools the rotor down faster.
    I paid:
    Rear: NZ$450
    Front: NZ$600
    check the URL: http://www.dba.com.au/dba_catalogue_...dard_index.htm
    Just make sure you have decent pads on them.
    2000 AUDI S3 GOODWIN GREEN | SUPERCHIP STAGE II REMAP | FULL REMUS CAT-LESS EXHAUST SYSTEM | EIP COMPETITION SHORTSHIFT KIT WITH STS | BMC PANEL FILTER | DBA FRONT AND REAR SLOTTED ROTORS | QUINTEN HAZEL PADS | CUSTOM ENGINE MOUNT | MORE TO COME SHORTLY...
    280 HP S3
