Volks AutosMonster Motorsport
Results 1 to 20 of 20
    Wicked666's Avatar
    Feb 2005
    Leeds
    574
    double din/satnav dash pics required
    considering changing mine but was wondering if anyone has any pics of there dash? Did the 8L models ever have this as an option?
    CHeers
    Jun 2004
    Surrey
    595
    Just done the single to double din just need to do some shaving of the navi and climate.
    rickquattro's Avatar
    May 2003
    Rickenback, German Black Forest
    588
    Here you go,
    http://smg.photobucket.com/albums/v6...r/Navi%20Plus/
    The alu strip at the top of the unit is from B&Q....
    Photos also in a thread in the ICE section, fitted by CraigyB
    Hope this link works and this helps..
    Rick
    Coming back to Audi with an A3 Tdi Sportback Quattro... but the 220bhp T5 was epic....
    Jun 2004
    Surrey
    595
    Rick
    What's the metal strip originally intended for as I need to get some for mine and I'm going to B&Q tonight.
    Wicked666's Avatar
    Feb 2005
    Leeds
    574
    impressive guys! I've got a prefacelift dash at moment...i'm not too bad at wiring things up. Reckon it's worth me giving it a go?
    Going to be using a double din HU as got a tomtom for satnav so that should make it a little easier
    Where did you guys buy the console from? rough prices?
    Jun 2004
    Surrey
    595
    If you have Tomtom why fit a double DIN? Not worth the hassle IMHO for a Symphony. I've had A Tomtom before with the wired into the stereo using the permanent docking kit and the sound was awful.
    If you were going to fit a RNS in there it's worth doing the wiring and facia modifications.
    Vagparts sell the cages in the Sat Nav section for about £70.
    May 2003
    588
    Quote Originally Posted by steve1975l
    Rick
    Steve
    I think that most people when they put the RNS-E into this model car, have a small gap above the navi unit. Some folk leave it as is, I wanted to fill it in to complete the job.
    B&Q have aluminium strip in the same part of the store as nuts and bolts.. Either bright or a sort of matt colour. Word of warning, its a very soft material and will mark easily as you cut it.
    Oh, did the link and pictures work ok?
    Jun 2004
    Surrey
    595
    OK thanks.
    Pictures are OK, the retrofit looks very good.
    May 2003
    588
    Thanks Steve, I am very pleased with it, its a real bonus in europe too.
    In answer to a previous question, the 8L were fitted with sat-nav as an option, using CD maps for each country. They also had, I think a cd changer for tunes.
    The RNS-E uses a Europe wide coverage DVD and SD cards for tunes. The dvd type was not an option in the 8L chassis, but along with others I have had it fitted into my car. And its ace. Works with DIS too.
    Aug 2006
    126
    i want to do this but my air con is in the middle how can i move it down,and can u get it to work as a dvd or tv
    Wicked666's Avatar
    Feb 2005
    Leeds
    574
    Vagparts sell the cages in the Sat Nav section for about 70.
    for this badboy
    http://www.caraudiodirect.co.uk/prod...oducts_id=4833
    70 isn't bad. don't suppose anyone knows if existing connectors will fit?
    Jun 2004
    Surrey
    595
    Quote Originally Posted by S3 03
    You need to cut the climate with a dremel or something similiar so it will fit. The sides and bottom need to be trimmed quite a bit to fit. It me about an hour at work to do.
    Aug 2006
    126
    do u need to cut the navi too,and does it need any more wiring or is it plug and play, looks hard to get a nice finsh.
    cheers
    Jun 2004
    Surrey
    595
    You need to cut the sides and the bottom, mine was an A6 unit. It takes a morning to do both climate and navi. I used a dremel cut tool to remove the excess and then the sanding tool to get close. I then used a long file to get a flat edge or nice shape. Measure twice cut once.
    I bought a CAN bus simulator with harness and the navi I bought came with a harness. I checked the CAN bus one and it had a mistake on the line out to the bose. Lucky I had 2 as I could use the pins out of the spare as I needed to try a few things. I have pin removal tools at work so it was easy for me. You may get lucky and get the right adaptor all wired correctly.
    nervus's Avatar
    Apr 2004
    1,116
    Nice mod but sounds like a right ballache!
    Jun 2004
    Surrey
    595
    Worth it IMHO as I hate the Tomtom style ring marks on your front screen which say to thieves come look in my glovebox.
    If you have the tools it's easy, just time consuming.
    Wicked666's Avatar
    Feb 2005
    Leeds
    574
    so is prefacelift to post facelift double din possible. WOrried more about the climate control connections. I imagine it'd be the same plugs in all honesty
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Looks good!
    Jealous for sure..
    Bet your super happy with it.
    J
    Jun 2004
    Surrey
    595
    Quote Originally Posted by Jampublic
    Looks good!
    Jealous for sure..
    I'd be lost without it...sorry could resist that one.
    Quote Originally Posted by Wicked666
    I doubt it. I would go for a single in dash flip out monitor if I were you...less hassle.
    Aug 2006
    31
    hi guys ive got a double din symphony 11 only problem is i havent got bose and to be honest the sound is s**t , i want to change to either a flip out monitor or the rnse as im told it will fit straight in. has anyone noticed a change when they have retro fitted an rns-e in sound?
    ive also been looking for facias for a symphony 11 but no one seems to make em so is my only option an rns-e?
    does anyone know if a double din screen will fit in ? or will this also leve gaps??
    thanks
