Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    problem fitting dv on s3
    Hey, i bought a new dv from audi cost me 24 quid, its the bosch one. But im having trouble fitting it, cant get the clips off, i managed to get the small one off the top but the other large clip and jubely(sp) clip i cant get too as there is no room. Help please!!!
    Also as i had all the plastic covers out the way i decided to try and fit my old bmc cda from my clio 172 and it fits and sounds awsome the dv is louder as well. But am i doing any damage to any parts of the engine by using it.
    Thanks guys
    Allan
    *update* just booked in 2moro at bigboystoys in essex to have a revo done and maybe get the dv fitted by them as well......cant wait!
    Jun 2006
    831
    I'm suprised the BMC CDA from a clio 172 was a straight fit to the S3 MAF! Something of a stroke of luck it matches the rather large 80mm MAF housing and had screw holes in the right place?!
    One thing worth checking is how the length and diameter of the Clio filter compares to the size that BMC recommend for the S3. If the clio filter is too small you may actually be restricting the amount of air the turbo can suck in.
    If it all fits securely and the filter is the right size then it shouldn't do any harm.
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    The bmc cda for the clio sport is massive as its for a 2.0L 16v engine, i read they are universal and range in size depending on size of engine. It fits perfect and sits nicley in the bottom part of the plastic airfilter case, there are holes where the cold air comes in which are right where the bmc sits.
    It sounds so much better and you can clearly hear the turbo spin up and the air escape like a normal dumpvalve. Nice with the windows down. probably losing power tho.
    Cant wait for 2moro!!!!
    Allan
    Jun 2006
    831
    Cool, the only reason i asked is that BMC list specific parts for CDA's to fitted to cars with Bosch MAF sensors.
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    ya ive seen a picture, it has a different adaptor to the one i have, its off now anyway, i got a replacement filter in the airbox and bought a forgue dv with the remap its running pretty good, just gotta use optimax or super unleaded to keep it running nicely.
    Allan
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    Jun 2006
    831
    Good stuff. Get Shell V-Power in it ASAP.
    Oh, and your signature... it's spelt Forge and don't get RS4's
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    thanks man ill change it, why not get rs4's what do u recommend, i also like the rs6 wheels. Do u think 18's will affect performance?
    Allan
    Jun 2006
    831
    Only kidding really, wheels are all about personal taste!
    New wheels will affect performance if they are significantly heavier than your current ones. Cheap replica RS4's will be heavy, Audi RSTT rims look like RS4's but should be a lighter than replica's.
