Monster MotorsportVolks Autos
Results 1 to 11 of 11
Thread: ko3 or ko3s?
    Mar 2006
    lincolnshire
    254
    ko3 or ko3s?
    i hae an a3 1.8t quattro sport 180bhp, which turbo will i have? its a 2000 x reg and its dbw if that helps, thanks
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    it will be k03.
    S3's have the K04 if i remember correctly
    Mar 2006
    lincolnshire
    254
    i know it will be a ko3 but will it be the normal one or the ko3S??
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    oh, um, i didnt know there were different types of k03....
    Jun 2006
    831
    if it was a year newer i'd say it's defo got a K03s. But you're right around the time they swapped from k03 to k03s for the 180bhp lumps.
    If you wanna PM me your chassis number i can have a look on ETKA and see what turbo Audi spec as a replacement.
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    925
    Mine is a ajq model 2000 on a w and it was a ko3 before i swapped it for a ko3s.Cheers Andy
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO MAP ,STATIS CATBACK EXHAUST,PANEL FILTER.
    Mar 2006
    lincolnshire
    254
    whats the differenc e between the ko3 and the ko3s? i know u can get mor epower from the ko3s but why?
    Wicked666's Avatar
    Feb 2005
    Leeds
    570
    after a swop is a new remap required?
    Jun 2006
    831
    K03s has a bigger inlet and slightly larger compressor, it can flow more gas than the K03 but still maintains the same housing.
    I've read conflicting reports on whether you can bolt on a K03s without another remap. You certainly couldn't run it without any remap and i don't think it should just be run with a generic Stage 1 map such as REVO (even REVO say their Stage 1 map isn't designed to work with it) as you may end up running lean.
    Most Stage 2 maps should be adaptable to give the required extra fuelling, but not all stage 2 serial maps are compatable with the ECU's that K03 cars came with. In that case you could go somewhere like Jabba who can do live mapping for fuel and timing.
    ANDYTQ's Avatar
    Oct 2003
    925
    I ran mine on revo st1 for ages waiting for revo to bring out st2 with no problems at all,ko3s just pulls more at higher revs and doesn't run out of puff at 5000rpm.If you already have revo its only 50 extra plus a 4 bar fuel regulater to switch to st2.Otherwise its jabba or custom code.
    Jun 2006
    831
    Quote Originally Posted by ANDYTQ
    Like i said, conflicting reports
    Unfortunatly, old-school AGU engines like mine can't have Revo Stage 2
    Which means i'd be looking a parting with about 400 - 600 to Jabba, plus the price of the blower. Then i'd have even more disgusting inlet air temps so i'd need uprated intercooling...
