    Aug 2006
    NI
    785
    Removing door cards
    any tips on this? I hate door cards the buggers never go back on right
    cheers
    -pablo
    back to boost, oh how I missed thee....
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    well in my experience they're pretty good on the A3 and go back on like they should.
    I leave the window up but others say it's easier with it down.
    Remove screws at each end of the door at the top (hidden when door shut)
    Remove the screw holding the trim on inside the interior handle.
    Pull trim off
    Remove unhidden screws
    Lift whole lot straight up
    Job done, then you just need to disconnect cables to suit etc.
    Aug 2006
    NI
    785
    excellent - got some components to fit asap
    cocain's Avatar
    RAA RAA like a dungeon dragon!
    Aug 2004
    The Sticks
    174
    the door cards is the easy bit fitting the components properly without the rings bending is the tricky bit. I hope u r going to give that door card a good dose of dynamat before you mount them because they will need them as the speakers are mounted on the flimsy door card.
    Aug 2006
    NI
    785
    oh yes dont you worry
    Ill figure something out lol maybe make some mdf rings.
    Aug 2006
    NI
    785
    now why dont all car makers make doorcards like that? Piece of pee!
    Just a pity my speakers dont fit
