Chris NottVolks Autos
Results 1 to 9 of 9
    darko's Avatar
    Dec 2004
    london, uk
    272
    Help removing wiper arms
    as title says, I need some advise on how to remove the wiper arms - they are very much stuck on ! Have removed the 2 nuts and used plenty of WD40 but still no joy - anyone have any tips ?
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    they can be a pain, 1 of mine flew off the other was a sod then just fell off. Try wiggleing the arm side to side with the main arm off the screen.
    red to red black to black blue to bits
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    2 options if there stuck:
    1. prise them up whilst driving the motor bolt down with a swift hit with a soft head hammer / or use a puller (like a G clamp with a V at one end that goes on the bolt under the wiper arm)
    2. (as I had to do after trying option 1) get a dremel and cut them off.
    Good luck
    S3(225) - Dolpin Grey | Leather/Silver Alcantara | Bose | ViperDV | Samco Hoses | Eibach Pro-Kit | H&R Spacers | Brembo GT kit | AreoWipers | BlueTooth | Dension Icelink | New engine, Clutch, Turbo, Water pump thanks to Cambelt @ 79,000 miles | New short engine thanks to ****ed valve 22,000 miles later!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I gave up trying to get mine off - but you can get one of those puller things from Hellfrauds for about 15.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    This is the sort of thing you need
    http://www.drapertools-online.com/b2...pp_skmno=13906
    Jason
    PaulRS3's Avatar
    UK
    1,006
    or put the nut back on a few threads, and use a pair of pump pliars, one side on top of nut, other under wiper and gently squeeze.
    this will pull them off the spline. the nut will save the threads being damaged, and also stop the wipers flying off.
    pullers are a pain on the front wipers, you really only need two legged ones, and even then its awquard.
    more info and pics here.
    http://www.wak-tt.com/mods/aerotwin/aerotwin.htm
    Audi RS3
    darko's Avatar
    Dec 2004
    london, uk
    272
    thanks guys ! in the end yes, a puller would not work and the arms were really stuck on - the method with the pliers worked perfectly, again this forum saves the day
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    change 'em to Aero wipers, that way it'll make it easy when it comes to changing wiper blades
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    darko's Avatar
    Dec 2004
    london, uk
    272
    i did
    look SO much better !
