Chris NottSky Insurance
Page 2 of 2 FirstFirst 12
Results 41 to 71 of 71
  1. #41
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    The theoretical max power of a K04 is 299.7 running at 31.2psi (2.1barg).
    [/sarcasm]
  3. #42
    Jun 2006
    831
    Quote Originally Posted by ChriS3
    C'mon, i'm sure the theoretical max power of a K03 is more than 200bhp but you never see real-world figures beyond that.
    This ain't a p*ssing contest. Simply pointing out the cast manifold is suitable for power beyond that of the K04; power that is actually achievable not just based on theoretical flow rates.
  4. #43
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Not a p!ssing contest at all, just pointing out the limits of the K04. ATP make no claims at 300bhp for their Eliminators. The GT2x makes its 290bhp, and the GTRS can make it's claimed 350bhp. Both proven at Star Performance and niether able to make the numbers on a standard manifold. I don't know of anyone running a GT2871R so I can't say much about it's apparent 400bhp..
    [/sarcasm]
  5. #44
    Jun 2006
    831
    ATP's on blurb, so take the power claims with a pinch of salt (as it should be with anyones power claim )
    The newly developed GT2X bolt-on turbo unit makes for an exceptional replacement for both the K03 and K04 turbo customer who likes their turbo in the stock location utilizing the stock exhaust manifold. This turbo is also for the customer that does not want to miss out on the low end grunt or torque of the stock turbo. However with the GT2X, expect to be pleasantly surprised by the flatness of the torque band and linear power delivery all the way to redline. Unlike the K03/K04 series, the GT2X has been designed to allow for a full power band on the 1.8T engine without choking up after 5000 rpm due to excessive backpressure at the turbine (a common problem even for customers that have upgraded from a K03 to K04).
    What makes up the GT2X is a combination of a highly efficient small frame Garrett turbo cartridge (consisting of a highly optimized wheel combination that is fully assembled and high speed balanced from the Garrett factory) and an ATP cast exhaust housing that has been designed to further optimize the turbo for the 20V 1.8T allowing it to reach its highest efficiency range during normal operation. The result is nothing short of spectacular an awesome breathing turbo and engine combination that likes to rev! In terms of performance, the GT2X (even though a non-ball bearing turbo) has the ability to start building boost right off idle speeds with more than 200 ft/lb of torque available from 2500 rpm all the way to redline, giving it the feeling of a powerful V8. This turbo, with its modern GT wheel aerodynamics, has the unique ability to make boost now and not make any qualms about holding the boost to redline.
    Have no fear about this turbo going KKKaboom. The GT2X turbo shaft is at least 25% larger than any K03/K04 turbo and since this turbo can provide peak HP without going outside of its peak efficiency range, it will not be forced to run at the reliability limits. This turbo happily makes a reliable 275 crank HP on pump gas and close to 300 crank HP on high octane.
    I'm sure the K04 could make 300bhp at 30-odd psi. No idea how you'd run that sort of boost on a 1.8T though. Perhaps i should have said the K04 is restrictive beyond 260bhp when operating within the boost limits of the other 1.8T engine components?
  6. #45
    Feb 2004
    UK
    1,320
    Hi,
    Remap,perhaps slightly tweaked ,260bhp 280lb/t
    After this prepare to spend 5-6k+ this should see a real 330-340bhp 320lb/t.
    Beware the Standard Yellow Banana!!
  7. #46
    Aug 2006
    NI
    785
    I have no problem putting 5k into the car to get an honest 350bhp.
    For now Im happy enough to do some chassis upgrades then go from there. Maybe build up the fmic/exhaust and as much as possible before swapping the turbo out. Im guessing the clutches will need to be upgraded etc so these can be done one by one to take the sting out of the final bill.
    Havent even picked the car up yet - roll on tomorrow lunchtime :D
    back to boost, oh how I missed thee....
  8. #47
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by Tallpaul
    Guess we don't agree on much then do we
    Guess not...
    As the ATP Eliminator Turbo bolts on to the stock cast Manifold and 300bhp has been 'claimed' stateside. Id wager the K04 becomes restrictive before the manifold. Why else couldn't you simply map the K04 to even 280bhp, let alone the claimed 300 (ignoring the fueling side of the aguement)?
    Have you ever looked at a standard S3 turbo manifold?
    You can hardly get your pinky doen the ports...pathetic.
    You can bolt a turbo the size of Bournemouth onto it, but if you can't get the gas out of te engine, you are wasting time, money and effort.
    I'm not saying you can't put a bigger compressor on a K04 and make more power...what I am saying it that you can get more out of a std K04 if you fit a better manifold.
    I guess both become a restriction eventualy - as stated correcly by Chris - but in my view, the manifold comes first...then the turbo when you are already pushing the limts of the combination.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
  9. #48
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by pablo
    I suggest you budget another 5k on sorting out the crap chassis and brakes before you even think of dropping 5k into the engine...or you'll end up with a very fast straight line machine that's dangerous in everything but a straight line.
    Sounds like that's the direction you are going anyway...
    Please note:
  10. #49
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    OT:
    Bl##dy hell Glen where have you been?! Long time no see.
    AL
    '07 Phantom Black S3 - '07 to now - Bucket Seats, FBMFSW, BOSE, Symphony II+, Cruise Control, Elec Folding Mirrors, Front Centre Armrest, Rear Armrest & Through Load, Interior Light Pack, Luggage Pack, Reversible Boot Mat, Luggage net.
    '02 Silver S3 (225bhp) - '02 to '07
    '99 A3 1.8T - '99 to '02
    '11 Rising Blue Golf R - '12 to now - 19" Black Talladega's
    '52 Black Golf GTi MkIV Anniversary - '03 to '12
  11. #50
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    My S3 was making 275-280 BHP on any dyno you care to point it at....with 320-330 lb-ft torque, on a standard K04 and manifold....running 1.85-1.89 bar peak boost and some very efficient intercooling.
    It was making those numbers 3 1/2 years ago...and 2 owners later, it's still making those numbers.
    Pump fuel..no additives, standard internals.
    I think there was perhaps abother 10BHP to go...and that would have been the absolute limit...
    Please note:
  12. #51
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by AL_B
    OT:
    AL
    I have been destroying rear tyres and brakes all round in the yellow thing in the pic below!
    Can't blame me for that, can you? :biggrin:
    Please note:
  13. #52
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Addicted before you've even started? If you serious about 350bhp at some point in the future, then it'd be worth looking into now to ensure that any engine mods are going to be compatable. For example, it might be worth just stick a metal sleeve in the TIP if it's not going to fit on a big turbo and will need replacing.
    But like Glen says, if you drop your money into the chassis first you'll be surprised how much speed you can carry through corners. His two year old advice still works good today
    [/sarcasm]
  14. #53
    Aug 2006
    NI
    785
    its excellent advice alright! Ill just have to see how it pans out. When something ceases to be adequate it will be upgraded. Thats the way I ran the M3 and ended out at a well sorted car.
  15. #54
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    what holds the turbo up is the tiny ports on the manifold. there is no pressure problem with a standard k04.
    just a little a6
  16. #55
    Sep 2005
    Manchester
    23
    [QUOTE=Ess_Three]
    The H&R springs are softer (less harsh) than the Eibachs...and compliment the Bilsteins well.
    QUOTE]
    Glen, have you tried the Eibach/Bilstein setup as well as the H&R/Bilstein set up?
    The reason I ask is I have just gone for the Eibach springs, and if they are harsher than the H&R I may go for these instead. I do a lot of round town driving where the roads are hardly the best.
  17. #56
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by 20valver
    Imola S3 had the Eibach / Bilstein combination on his S3...and they were slightly harsher around town, as normal with Eibach springs, in my experience.
    I don't recall there being much between them on the roads with the speeds high though...just the H&Rs semed a bit more compliant on potholes etc.
    Please note:
  18. #57
    Aug 2006
    NI
    785
    anyone tried the koni kit? adj shocks and springs for 380 ish. seems good value.
  19. #58
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Konis tend to be harsh too...
    I've had them on enough cars in the past (still do on my GTI).
    I remember going for a spin in a TT with Konis on...good, but not as polished as the H&R / Bilstein combo.
    Felt more harsh around town...too stiffly damped. Never got the chance to try it flat out on the open road sadly.
    Please note:
  20. #59
    Feb 2004
    UK
    1,320
    I'd agree with the above comments,any mods made at this stage need to be compatable with future mods.
  21. #60
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    The uprated manifolds that Star have aren't for the S3 or TT225. Jim should be getting some S3 ones soon (ATP), but he's just fitted the one he had to my car :biggrin:
    I stand corrected, none of the ATP manifolds fit the S3
    They've taken my one out and had to put the standard one back in, big waste of time and money.
    [/sarcasm]
  22. #61
    Aug 2006
    NI
    785
    gutted mate I was going to order one too!
  23. #62
    Aug 2006
    NI
    785
    picked it up today pretty happy with it but the suspension definately needs sorting. nailed on a wet roundabout the rear end was twitching like mad and I could feel the back end want to go. so definately want a suspension kit. just finding it hard to decide. koni is good value but dont want to loose too much comfort. cant find any info on the billy shocks to mate with H&Rs. Might give star a bell tomorrow see what they have unless there is someone else I should be talking to?
  24. #63
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    The back end wanted to go? Are you sure?
  25. #64
    Aug 2006
    NI
    785
    yup! could feel it twitching. nearly new F1 tyres on too
    tried to PM you to see if you had any stuff left mate. lemme know if you do.
  26. #65
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    The S3 understeers out of trouble, so the arse twitching sounds very strange!
    All stuff sold now... the springs and dampers were sold today.
  27. #66
    Aug 2006
    NI
    785
    aw crap Id have bought them off you.
  28. #67
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by Imola_S3
    My thought exactly...
    It took me 3 years, 1000s, some aggressive suspension geometry and 330 lb-ft of torque being tricked into being dumper rearwards to get the back to wag on my S3.
    Standard all they want to go is plough straight on...if yurs has a wayward back end it ust be broken.
    They just don't do that normally.
    Please note:
  29. #68
    Aug 2006
    NI
    785
    maybe stepping out is the wrong description - I could feel the left wheels oscillate up and down a bit on hard cornering (turning right) in the wet as if it was about to slide.
  30. #69
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    That's the S3s ****, underdamped suspension at work there.
    It's awful...
    Back to my point about sorting the chassis out long before you add more power....with the suspension sorted to such an extent that you know exactly what the car is going to do at any time (which you can't predict with the wooly under-damped standard set-up) you'll find you can push the car harder and will be much quicker point to point.
    I had my S3 step out twice...properly step out..as in pointing 90 degrees to the direction of travel...and it was down to the unpredictable Haldex system....that situation is not nice I can assure you.
    Gave me a proper fright...
    Please note:
  31. #70
    scott_johnson's Avatar
    Audiless
    Bingley
    875
    Arnt the b5 rs4's running ko4's ??? Dunno if there the same (i no theres 2 of em) but there good for 450-500bhp???? my mate had an amd mappd b5 rs4 running 440ish...... fast as foooooooooooook. lol.
  32. #71
    Dec 2006
    139
    I have an APR remap, milltek cat back, green panel filter, DV and it's running pretty well now.
    The next step for me is the manifold that should see nigh on 300. Then I'll see how quickly I bored before upgrading to a new turbo!
    Goodwood Green 2001 AMK S3
    AMD remap
    Miltek cat back exhaust
    Viper DV
