Results 1 to 11 of 11
    Aug 2006
    Glasgow
    24
    Sort of flat spot
    Hi,
    If anyone could shed any light on this problem.
    I have a V registered A3 1.8 Sport which seems to have this sort of weird flat problem some times it kind of feels like a miss about 2000rpm and sometimes you can be driving on the motorway at about a steady 70mph give or take then for no apparent reason it feels like someone has switched off the ignition for about 2 or 3 seconds as it sort of coasts with no power whatsoever then miraculously bursts back into life again.
    keep on hearing from so called amatuers that talk about all these sensors i.e. airflow camshaft, crankshaft etc, but there are loads of these things in cars nowadays and i don't really want to start buying all these i would rather have someone that could be a bit more accurate.
    I love my A3 but i was brought up with the old ford crossflow engines which was easy to fix and you could count on one hand what would be wrong with it and fix it yourself unfortunatley i don't have that luxury with my A3 as the engine compartment looks complicated but i would tackle replacing a part with a haynes manual if someone could point me in the right direction as to what the problem could possibly be.
    Any info plz guys
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    This sounds like the classic symptoms of a failing MAF(Mass Air Flow) sensor, which sits just after the airbox. Look in the FAQ's section or do a search for 'maf' for more details on how to test it.
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    Deffo mass air flow.....these things a prone to "go" on audi's.
    I had 5 on my S4 and on my 2nd on my RS4.
    Aug 2006
    Glasgow
    24
    Can you please tell me roughly how much these MAF's costs ? and also are there better one's than those supplied from a dealer.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    Quote Originally Posted by Cannonz
    They are 80 exchange at your local stealers, change it yourself, it takes 10 minutes for beginners, or pay 30 quid for 1/2 hour of stealer labour charges!
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    for this problem and any future problems get your car vagcom'd and you will know for sure what is wrong.
    just a little a6
    Aug 2006
    Glasgow
    24
    I know i'm a little wet behind the ears here since i'm new to audi's but this vagcom your talking about do i have to go to an audi dealer for this if not do you know of anywhere near Glasgow that i could get this test done and if so what's the average going rate for this kind of thing.??
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    you dont have to go to an audi dealer, you can buy vagcom here :
    http://www.ross-tech.com/vag-com/index.html
    Aug 2006
    Glasgow
    24
    Just downloaded software from site, i've ordered the usb connecting cable from ebay for 15 quid, will let you know how things progress
    Aug 2006
    Glasgow
    24
    just got my vag-com 409.1 cable through today lights up ok installed drivers ok done the led test and got the response port status: OK led test complete.
    But when i hit the test button i get port status: OK Interface: No Found
    any ideas guys...???
    Also i've noticed that looking at the vag-com cable only pins 2,4,5,7,10,15 & 16 are connected and looking more closley at the the purple comms connector at the back of the centre console where it plugs into i've noticed that i can only see pins 1,4,5,7,16 connected is there a reason for this..??
    please don't tell me that i've got the wrong cable.
    Any info plz
    May 2003
    Reading
    705
    Are you definitely using the right COM port? I had the same issue, I thought I was talking to the cable and it said the port status was OK but then wouldn't work in the car. Turned out I was talking to the builtin modem in the laptop!! The cable had been installed as COM port 7 or something, changed that to COM 3 and it then worked fine.
