Results 1 to 8 of 8
    Aug 2006
    31
    DUMP VALVE GOOD OR BAD FOR S3???
    HI IVE PUT A DEPOSIT DOWN ON AN S3 AND LOOKING TO MOD IT, ANYONE KNOW IF ITS A GOOD IDEA TO PUT A DUMP VALVE ON IT OR IF IT CAN BE DONE, IF SO WHATS THE BEST 1 FOR THE CAR??
    DO YOU GET ANY PROBLEMS??
    ALOS REMAP ????
    HEARD AMD ARE GOOD HOW ABOUT REVO?
    THANKS VERY MUCH
    CHRIS
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,285
    Atmospheric dump valves don't really good well with the 1.8T engine and normally send the ECU mad, the best thing to do is to get a uprated divertor valve like a Forge Eliminator or 007P. As for the remap, it's a must when you get an S3 and there's plenty to pick from all depending on how you want it. Anymore help just give us a shout and we'll be able to sort you out!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    icenutter's Avatar
    Jun 2006
    595
    If you do a search on this fourm you will see that you can definately fit one. The jury is out on whether they are 'bad' or not. But if you just want the noise then I suppose it doesn't matter.
    Also please don't write all in capitals as it is very hard to read and looks like YOU ARE SHOUTING ALL THE TIME.
    Jan 2005
    Colchester, Essex
    147
    Worth having a search for more info on both topics, here's a bit on dump valves:
    Dump Valve for Audi S3 1.8T??
    Jul 2005
    2,488
    theres some good stuff on audiworld about this. and some strong debates for and against. The bottom line though is that if you're going to fit one, make sure that the valve closes fully at idle so that the idle isn't lumpy. Most'll require a stiffer spring and a few shims to do this apparently..
    Jun 2006
    831
    Here's a long winded but very good explanation of why atmospheric dump valves aren't good for your 1.8T (not written by me):
    A modern engine management system, ie the Bosch Me unit fitted to 1.8T's has "adaptive" learning on the fuel, ignition and airflow side.
    Because Me is a Torque based structure it's calculation of engine torque verses driver demand is critical to the driveability of the car and it's performance / durability.
    When you fit a "leak" in the intake system (open circuit valve) the original calibration of the MAF sensor to manifold and cylinder filling modeling will not corespond. However due to the 20% allowance in the long term adaptive values the ECU will relearn you engine and "leak"
    At idle the inlet model calculated airflow will exceed the MAF meters measured output, and depending on the state of your particular components - ie MAF ageing / contamination, throttle plate leakage, Fuel tank purge vapour concentration this may, or may not push the adaptive to it's 20% limit. If it hits the limit the ME unit will run in FMEM mode (Failure mode and effects management) causing reduced system efficiency. The Me unit will use the switching signal from the lambda sensor to return fuelling to lambda 1, storing the correction as a map agaisnt airflow. and add this correction to the fueling calc when operating at non closed loop conditions, ie WOT, fuel injector reenstatment (after overrun shut off, traction control intervention etc.) Now depending on how you drive and how sensative you are this may or may not be felt by the driver during certain manovevers. The throttle plate position will also learn the new airflow to maintain control of idle speed, but you may notice poor engine load rejection, ie turn on the aircon and the engine speed varries etc. or engine speed flares on starts or when operating PAS when parking.
    However in all cases this will result in "incorrect" fueling. Now by "incorrect" i mean, not as the manufacturer intended. A post MAF leak will cause rich operation initially, but the adaptives will pull fuel out and become negative. This tends to cause a rich to lean spike on tip outs and other throttle transient. Now it is extremely diffucult for an untrained observer to spot these effects as they occur mainly on throttle transients, when the average drive may not notice. Therefore you could say "why do i care?". Well, any AFR excursion from the intended fuelling set by the manufacturer will result in non-standard engine operation. because of the adaptives this is unlikely to cause immediate engine problems, but over the course of time will change things like catalyst ageing, exhaust and turbo charger valve durability etc. Manufactures spend millions accruing miles on development fleets so hopefully the customers don't get landed with big bills as time goes on, and with most modern cars life'd at 150k miles (min design life) this is a big task.
    It is unlikely that this will result in any performance loss, as at WOT the system is open loop, but you may see the result of an open circuit valve oas over fueling on gear changes etc. (a tell tail puff of black smoke is what you can see, a 1200 degC Catalyst is what you can't see, as excess fuel when injection reenstates and excess air from overrun shut off period combine in cat)
    Now as you can see this is a seriously complicated subject and i haven't even mentioned the dreaded EOBD or OBDII words yet. Typically Bosch Me units have approximately 9000 calibratable parameters (constants, maps etc) and an engine calibration program will take a team of 8 calibration engineers 18 months to do the basic mapping and OBD validation. These days it's no problem to do the basic fuel and spark mapping, maybe 4 weeks on a midlimit engine on a dyno, but the diagnostics and emmisions devs takes years.
    Moral or the story, before you start playing with something you don't understand, find someone who does!(And not just thinks they do!)
    (for anyone thinking, "hey what makes me such an "expert" on this subject?" then i'd better mention the last 10 years i've spent as a senior calibration engineer at Cosworth and Prodrive!)
    Jul 2004
    Cambridge
    339
    Any ideas of the author
    Hi Paul,
    Any ideas who wrote that article regarding calibration? I'm beginning to wonder if having a car remapped is such a good idea given how much R&D goes into the initial map to begin with.
    Work commute:
    Honda CBR 1000RR
    169 kg & 170 bhp - eeek!
    Backdraft Big Turbo Silver S3, Supersprint, Eibach lowered, QST rear tiebars, SPA boost gauge Sold
    Lotus Elise 111R also Sold
    Wanted: Honda powered Lotus Elise S2
    Jun 2006
    831
    Quote Originally Posted by glen_jai
    Hi Paul,
    You'd be suprised how much R & D goes in to remaps too.
