Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    Question Goodridge Hoses, anyone fitted these?
    Hi, Just fitted a set of these hoses to my car as I have been upgrading some brake parts. The Hose set only contains 4 hoses, yet there are 6 flexible hoses on an S3. So my question is why did they miss the final set or did I get an incomplete set??
    PS for those that haven't looked there is one hose per front wheel and 2 hoses per back wheel, one so you can remove the caliper however this one doesn't flex in the normal running of the car, the other is located further up the brake line this will flex due to suspension movement of the car - this is the one supplied.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    I was looking at doing this mod a while back, but was told that the standard flexi-hoses on the S3 are pretty much the same thing, except for an extra plastic coating on the outside.
    [/sarcasm]
    Mar 2005
    Chorley, North West
    167
    Black Diamond do just the front lines on there own. I fitted these to my A3 Quattro. The rears were small so didnt replace them.
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    so are the standard S3 brake lines metal?
    Call of Duty Zombie Slasher.
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    563
    Quote Originally Posted by fasteddie
    That would be partly my fault as when I took the hoses off my car for Goodridge to copy them between us we decided not to bother with the hose that is crimped to the brake pipe.
    99 S3 Absolute red
    mintie's Avatar
    Jun 2006
    Asford
    154
    ive just put braided hoses on my S3 and the kit that ive put on only came with 4 lines, where do the other 2 go????
    thinking about stuff
    May 2006
    Leeds
    599
    its a good mod to do if your brakelines need replacing but if there fine don't bother. You get a slightly firmer pedal and a more direct feeling between the pedal and the brakes.
    2001 Black RS4 - P11 LCC
    1992 Burgundy Pearl Corrado VR6 - A20 LEE
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    563
    If you put Goodridge hoses on though they will last for ever
    99 S3 Absolute red
