AH FabricationsEM Tuning
Results 1 to 7 of 7
    Burnin' the clutch
    Aug 2006
    Sony GT headunit to Audi A3
    OK gents I've got a sony GT head unit in my audi. Took me ages to get the cable to connect it. Anyway got it going but barely. All the speakers work but the sub doesn't! Any1 know how to get it going?
    MIKEY
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    I take it you used an ISO block connector ? have a look at the original one and see if there are any wires which dont connect on the other end of the block
    Burnin' the clutch
    Aug 2006
    Everything looks connected. Am i right in thinking that the concert system might have some sort of special direct link to the sub, Something that the sony system might not have?
    MIKEY
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    wen i had mine done i needed a bose adapter so that the sub nad amp all works
    hope that helps ?
    it isnt cheap by the way!
    Jason
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Got it working yet?
    So do we get to see a photo?
    I am interested to see how it looks!!
    J
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,052
    The factory sub (and rear-speakers AFAIK) run from a MOSF... er, "amp" - If you've just got the ISO power-block and ISO speaker-block plugged into the HU (the two large plugs), you haven't got the amp connected. The connection for that is one of the smaller plugs that connects above the other two (well, on the Concert HU anyway).
    IIRC (and as previously touched-on) there are two adapters available to connect an aftermarket HU to the Audi amp - one is for cars with Bose, the other for those with standard systems - they're both available from caraudiodirect.com and the like. However, (and again IIRC) they basically convert a speaker-level signal coming from the ISO speaker-block into a line-level signal for the amp. If you're anything like concerned about sound quality this isn't ideal.
    The best thing you can do (I'd say) is look at connecting the Audi amp to the pre-outs on your HU - I'd guess the connections are similar if not identical (beware, pinout is probably different even if the plugs are the same). I wouldn't have thought it would be a particularly complicated job - if you can maybe post some more details about the stereo (exact model number), and what connectors (colour, number of pins etc.) you have left over from the Audi loom; I'm sure I'm not the only person on here who'll have a stab at advising you what's what. [Worth noting of course that if you can, posting pics to go with your descriptions will probably expedite the process]
    Regards,
    Rob.
    col6821's Avatar
    Feb 2006
    Warwickshire
    175
    Did you use an Autoleads ISO connector?
    I tried this with an Autoleads PC9-401 but got interferrence through the rear speakers as the headunit had a built in amp.
    At first the rears and sub didn't work as I hadn't connected the head unit switched feed (blue wire) to the autoleads lead.
