AH FabricationsChris Nott
Results 1 to 19 of 19
    Jul 2005
    2,488
    Diverter Valve q's
    hopefully someone can help me out here...
    After 36k on the original DV, its about (over) time to change it. Im not noticing huge performance problems, but it does feel a little laggy, and I can hear the turbo hiss much more than on my brothers TT.
    The questions are:
    1. I still have the factory crimp connectors on, I know that these are not reusable, but what are the sizes i need for the vac, boost in, and boost out pipes? Yes i know i'm lazy not to just measure them...
    2. Some people replace the vac hose when replacing the DV. Is this really neccessary?
    Cheers.
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    I believe the crimp connectors are re-usable, you just need the special tool to release them. I just used jubilee clamps on the wifes A3.
    cant answer number 2 for you
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    1. measure them you lazy get :D
    2. you only need to replace them if they are worn.
    just a little a6
    Jul 2005
    2,488
    haha, unless I can find a VAG crimp tool, I'm gonna have to get off my arse then!
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    once the vag's are off don't bother with them, jubilees do nicely, get smallest for the vacs, dv's are around 30mm
    just a little a6
    Jul 2005
    2,488
    nice one, thanks!
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Just like madvw I have noticed a slight drop in performance recently.
    My car has not been pulling as it has been and it seems you need to really press down on the accelerator to get any performance instead of just part throttle.
    I have changed the DV back to the original one from a Hyperboost one and the difference was amazing, I get a more noticable boost noise from the DV instead of a weak wooshh that I used to get and car pulls better on part throttle.
    Do these DV's ie the Hyperboost ones weaken over time?
    Just that on my previous S3 this DV was sticking, it was supposedly serviced and good for use again but seems to have broken again? The spring seems softer when pressed than the original Audi OE one, would this make me lose boost if it takes little pressure to lift the piston?
    For info the Hyperboost one has probs done around 45k on the original spring and seals etc...only being cleaned and lubed up with oil.
    Any comments would be appreciated!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Quattro_Lew's Avatar
    All Torque
    Sep 2006
    Radcliffe, Manchester
    206
    in and out tubes are 30mm and i just re-used the vac one, job done
    2000 A3 T Sport Quattro
    Absolut Red
    225 Bhp Remap
    mattyboy199's Avatar
    Nov 2005
    UK
    1,679
    can anyone show me where the DV is located ?
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    I used jubilee clips, much easier even though if you have the tool you can re-use the clip ones. Vac hose doesn't "need" a clip as it is sucking so only put one on if you'll worry about it!
    P.S. take the engine cover off and the DV is behind the head and slightly to the right. Follow the hose from the airbox to the inlet and you won't miss it!
    dultanur's Avatar
    all promises, no action :)
    Sep 2006
    Istanbul,Turkey
    407
    jamS3, maybe your DV needs a rebuild? piston type DVs leak air as the grease gets pushed away...won't seal properly. but i don't know how often they will need a rebuild.
    2000 Black S3 (Sold, then totalled) - 2008 A3 1.4T Sport
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,468
    Quote Originally Posted by Quattro_Lew View Post
    can someone confirm this?
    Nov 2005
    UK
    1,679
    yes this is correct however the jubilee will need to be larger.
    wanted for 8L S3:
    Milltek system
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,468
    I think I may have confused myself and you.
    Inlet and outlet of DV. Not the 'tubes' which the op refers to, I.e. External diameter of pipes.
    I need the internal diameter.
    Midlands
    281
    Im on 138k and it was only changed about 30k under warranty.
    Should I replace mine? Haven't noticed any problems though.
    Dave
    2001 S3 | 210/256/270 switchable APR software | Absolute Red |
    Nov 2005
    UK
    1,679
    internal diameter must be about 25mm.
    Dave no harm in changing it, buy a forge or bailey item. I would also check for boost leaks.
    wanted for 8L S3:
    Milltek system
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,906
    Visit 16Klappe's Instagram Channel
    The DV inlet and outlets are 25mm.
    Epic thread bump Karl.
    /thread.
    I quite often say I'm going to do things.
    Then never do them.
    Midlands
    281
    Quote Originally Posted by mattyboy199 View Post
    I'm too old for a psst between changes
    How do I check for leaks?
    Dave
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,468
    Thanks jardo
