Sky InsuranceAH Fabrications
Results 1 to 19 of 19
    clcollins's Avatar
    Mar 2004
    Lancashire
    276
    Unhappy Indicators not working properly
    Hi all, wondering if any of you have had / or heard of a similar problem. My indicators seem to have died…………when I indicate they do one of three things, (1) nothing, (2) flash for about 2 seconds at three times the normal speed, or (3) flash once at normal speed.
    I’m hoping it’s just the flasher unit but have a feeling that it’s the indicator stalk. My reason for thinking this is that when I put the hazard lights on the lights work perfectly, so unless there are two flasher units (one for normal indication and one for hazards) then it’s the stalk.
    Anyone got any ideas / advice?
    cocain's Avatar
    RAA RAA like a dungeon dragon!
    Aug 2004
    The Sticks
    172
    umm not sure but i remember when I changed my sub over in the back of my A3 a while back I had some strange things like that happen to my indicators. took it apart and went through the whole process again and it was ok. I asked someone and they said it may have been a dodgy earth wire in the loop but your case may be different.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Yes, a dodgy earth on the A3 makes the dash go funny in a spooky sort of way, indicators become intermittent and the dash lights flicker all over the place.
    You've got to have a laugh! For Sale:LCR Brakes - ÂŁ400
    MarcA3Turbo's Avatar
    Jan 2006
    Dublin
    56
    Had a similar problem a while ago. Replaced the relay, but it didnt solve it, so have now put it down to the indicator stalk itself. Theres a replacement stalk on the way to me at the moment, so if you want I can let you know how I get on? And theres only 1 relay for both the hazards and the indicators. And I had the same symptoms too i.e hazards worked fine but indicators play up.
    HTH
    Marc
    2001 Brilliant Black A3 Turbo, Bose, Audi iPod Kit, TT pedals, S3 Spoiler
    clcollins's Avatar
    Mar 2004
    Lancashire
    276
    Quote Originally Posted by MarcA3Turbo
    HTH
    Marc
    Marc have you changed your indicator stalk yet, if so has it sorted out the problem?
    As I have the same prob and really don't want to change the stalk without knowing for sure that's where the problem lies, how do I trace an earth fault (if there is one)?
    Jan 2006
    Dublin
    56
    Hi,
    indicator stalk was posted yesterday, should have it tomorrow, but I'm away until next Wednesday, so won't have it on until at least then, sorry! I'll let you know though as soon as I get it on.
    Marc
    davidhodgkinson's Avatar
    lancashire
    198
    If your after a stalk I think I've got one around somewhere
    Was A3 1.8Ts
    Now S3
    Jul 2005
    2,488
    have you replaced your stalk yet marc? did it fix it?
    Jan 2006
    Dublin
    56
    No, believe it or not, still haven't gotten around to it! Have the new stalk sitting in my glove box, but haven't had it fitted yet. The problem is so intermittent i.e only happens for a few minutes every few weeks that it keeps slipping my mind. I'll make the effort to head down over the next couple of days though, just pure lazy really...
    Jan 2006
    Dublin
    56
    Eventually got around to fitting the new stalk last week, and glad to report that the problem is completely cured! Happy days
    Jan 2005
    60
    I had a similar problem.
    Hazards worked 100%, but not indicators.
    A new relay fixed everything. It is very easy to change, so you should give it a go :-)
    Dec 2006
    190
    indicators
    I have got the same problem with mine, Spoke to Audi and they said it is a common fault and 9 out of 10 times is the hazard light switch blocking the signal of the indicators. Havent brought or fitted anything yet though so would be intersted to hear how you get on.
    bthechronic's Avatar
    jack
    Mar 2009
    todmorden
    audi a3 quattro 1.8 turbo ,,,will you please tell me how you get on clcollins as i have the same problem by the sounds of things ,,,and can any one tell me how much the indicator stalks are,, do i need to change the relay as well all info greatley accepted
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Quote Originally Posted by bthechronic View Post
    Mine was doing this when I test drove it before I bought it and one of the mechanics at the shop said the hazard relay was a common problem. They swapped the whole hazard switch bit out from an A4 and I haven't had a problem since.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    s3 tys
    Oct 2008
    St austell, Cornwall
    88
    this happened on my s3 and was the relay just replaced it , it just plug in
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    that was two and a half years ago so hes probably had another relay since then
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Quote Originally Posted by voorhees View Post
    Probably a new car
    adz_rolls's Avatar
    S3XY
    Oct 2008
    Southampton
    58
    this has just happened to my s3. what part do i need and where do i get it from? and how do i fit a new relay? cheers
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    Hi mate, the flasher relay replacement is a 15 minute job if you have all the needed tools. Go to Stoke Audi section on here and request the part from Dave. Given a chassis number he can give you the correct part. I think it's in the region of 25 pounds, so not too big of a deal.
    To replace the relay (it's one unit, but contains two separate relays - indicator relay flasher and hazard) you will probably be better off by removing the stereo to get a good grip on the panel that covers the top part of the central console (cup holder, ESP buttons and hazard button/relay). I managed to remove this panel without taking the stereo out, because my car had a bigger gap than usual, so a blunt/flat table knife went in there nicely.
    In any case, carefully lever off the panel from the bottom and then pull the panel slightly up and towards you. It's held in with clips, so be careful not to damage any of them.
    The next part is a little fiddly, but you will need to get a flat screwdriver in the corner of the hazard switch and lever it out of place. Once out, it's just a matter of un-clipping the connector replacing the flasher with the new unit (test the indicators at this point) and push it back into place. The rest is in reverse.
