JMB RetrofitsChris Nott
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Smile Standard Turbo + Remap. Any other performance parts worth fitting?
    As subject I'm looking at getting my AGU Engined car remaped, but are there any other performance parts worth fitting before I have it remaped?
    Already got:
    2.5" CAT back system
    Carbonio CAI
    Forge T.I.P
    Maybe 4 Bar F.P.R, S3 injectors + Fuel pump, Low temp plugs?
    Are these worth doing? Or are they only needed with a KK04 or bigger?
    Mark
    Pirates black Honda Accord Type-R VTEC
    May 2003
    Reading
    705
    FMIC?
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Quote Originally Posted by j4jon
    FMIC?
    Will only be running 1Bar boost. So don't really think one is needed.
    Feb 2004
    UK
    1,320
    decent dv, you don't need all the fuel stuff as the turbo won't produce that amount of flow.
    Beware the Standard Yellow Banana!!
    May 2003
    Reading
    705
    Thats all I'm running but it is noticably slowly when the weather is hot, so it would then help to keep the intake temps down. It's just kinda expensive thats all.
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    if i were you put all those bits on and get a k04 bolted,, then later the remap, maybe get a FMIC inbetween
    k04 will give some nice gains at top end and be driveable like your old k03 even on standard map
    just a little a6
