Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    help understanding my DIS warning.
    Just driving home from tescos and a warning comes up on the dis that i havent seen before and i dont have my handbook with me.
    Its basically a circle with what looks like brackets either side. Im thinking its the breakes?? but what exactly.. they seem fine and all have good depth left.. unless its one of the pads??
    Its in audi on friday anyway so they cancheck it out but i presume its safe to drive until then?
    Age 18: CRX MK2 | Age 20: Corrado VR6 | Age 21: Audi S3 (rip) | Age 23: Audi S3 | Age 25: BMW E46 M3
    monkeytrousers's Avatar
    Jul 2004
    East Sussex
    372
    I think it's brake pads.
    Audi A4 3.0 TDI Quattro 2008 - Ice Silver
    JUST GONE: BMW 330i M Sport Saloon 2006 - Le Mans Blue
    GONE BUT NOT FORGOTTEN: Audi S3 Quattro 2002 - AMD stage 1 - 261BHP - MTM clutch - Brilliant Black
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    pads, or at least the nearside ..... if its just come on no panic, there is a good 2.5k left
    S3(225) - Dolpin Grey | Leather/Silver Alcantara | Bose | ViperDV | Samco Hoses | Eibach Pro-Kit | H&R Spacers | Brembo GT kit | AreoWipers | BlueTooth | Dension Icelink | New engine, Clutch, Turbo, Water pump thanks to Cambelt @ 79,000 miles | New short engine thanks to ****ed valve 22,000 miles later!
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    cheers... will last till friday then
    incidentally its going in on friday to have the headlight adjuster motors changed... thats the second s3 i have had to do this to now!! cant previous owners notice the lights wander and are extremely dangerous!!!
    *rant over*
    nervus's Avatar
    Apr 2004
    1,116
    Theres a wear sensor on the pads which is basically a wire set into the pad and when its broken through it opens the circuit and throws the warning. It may well be just one inner pad but they must be near if one has gone. Still there is a good 2K in them and the front pads are only ~40 from GSF and similar.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Quote Originally Posted by nervus
    its when it makes a circuit, 2 wires embedded in pad finally both touch the disc and make the circuit, light comes on.
    nervus's Avatar
    Apr 2004
    1,116
    Quote Originally Posted by S3_MCD
    Oh, ok I couldnt remember which way the S3 was set up as I just changed like for like last time. I fixed simiar prob last week on a collegues Vectra which breaks the circuit to throw the fault and assumed it would be the same.
    He bought pads for a lesser model which didnt have the sensors and on the old pads you could clearly see the little node with the broken wire so we ended up just shorting the supply circuit so I dont think he'll get the warning again.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    no nervus you were right and I should know ive just this minit done my discs and pads. The light comes on when the wire is broken. the sensor is on the inner passenger side pad.
    on another not I got discs and pads from GSF and the outer pad had a large sticker on it like double sided sticky tape. first time ive seen that on a brake pad. I normally copper slip that area but not on these pads.
    red to red black to black blue to bits
    PaulS3's Avatar
    UK
    988
    Exactly as per fingermouse and Nervus.
    link in the pad gets broke, sets off light.
    If you install pads with no sensors you have to short out the lead to get rid of the light or recode the car, to do away with pad sensing all together.
    As mentioned its only the passenger side front that has the sensors.
    Audi S3 Quattro Black Edition.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    You still can't beat a visual inspection - my pad warning light went on and it was the sensor at fault and not the pad wear device.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    I take it all back .... thats 4 against 1 !! - so sure I was right.
    pazaz's Avatar
    May 2004
    S.Wales
    316
    My Brake pad light is coming on intermittantley together with the ESP light.
    Can anybody advise me of what the problem may be?
