EM TuningVolks Autos
Results 1 to 11 of 11
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    Unhappy Starting Problem
    Evening all,
    I've loved every minute of owning my S3 for the past year and a half and apart from the usual arb and maf replacements have not had any problems at all until this evening...
    ...key in ignition, dash lights come on, get the ok sign but wont turn over. The car is unmodified and its been just over two weeks since it had the 60k service. Has anyone had similar problems previously or know what the problem may be. Any help would be appreciated.
    Jul 2005
    2,488
    nothing whatsoever? no click, dimming of lights? no slow crank?
    could be a knackered starter? or starter that hasn't disengaged properly.. Can you rock the car in fifth to see if you can free it at all then have another go?
    Jun 2003
    World of my own
    9,813
    Not sure if this applies to S3's but I recently burnt out my starter motor on my A4 as it was cranking with the engine running due to a faulty ignition switch. The switch felt loose and wasn't springing back from the cranking position properly. This is quite common on A4's but haven't heard of the same issue with A3/S3's.
    Is the immobiliser different on an S3? With the A4 (B5) it allows the engine to crank & start but then dies immediately, some immobilisers prevent the engine from even cranking, so could be the common reader coil issue?
    Again not sure if this is common on S3. Have you tried the spare key?
    You can check if it's a starter motor problem by bump starting it. If it's an immobiliser problem then it won't bump start.
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    well, hard to describe really (I'm no expert) but apart from a few strange clicks that seem to be coming from around the aircon controls and a brief (almost silent) clicking noise from the engine.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,532
    Flat battery?
    marmite's Avatar
    Counting the Tesco Club points
    Jul 2006
    Barnet
    1,070
    sounds like a battery!
    you got roadside ass
    Audi RS6 Daytona GreyLoving all 455.7BHP of her
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    The car is used on the regs and I also did a round trip to Heathrow on Saturday (spotted a couple of S3's on route) unless the battery has suddenly died?? It’s as if the immobiliser is still active but I really have no way of testing etc…
    Best thing of all is the car is still under extended warranty. I called yesterday evening but they could only send out the RAC and I have use of another car so I opted for an Audi Tech to come round at some point today.
    Thanks for the response chaps; I’ll let you know what the problem was when it hopefully gets sorted today.
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    All sorted, spot on lads (Battery). Sounds simple enough but I thought my baby had died on me and with no way of checking feared the worse.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,532
    So long as shes back on the road mate
    Aug 2004
    526
    Quote Originally Posted by Maz
    Did they find a reason for a drain on the battery or was it just knackered? I've run mine flat stupidly twice since getting the car through looking in an A to Z / map in the car in the dark and then leaving the light in the on position (doh!).
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    I think it was just time to get a new one mate. The Audi Technician said there was no way of telling what had caused it. I hadn't left any lights on as the reading he got whilst checking was still high enough for central locking, lights etc to work but not enough to start the car. I've since purchased a new Bosch Silver Battery so hopefully it wont happen again some time soon.
