FK Spacer question....
Bridger
NULL
Hi there, just brought some 15mm wheels spacers for the rear of my S3, they are the ones which bolt to the hub then the wheel bolts to the spacer, trouble is the wheel bolts are bottoming out when i try to do the wheel back up, is there anywhere that sells shorter bolts or can i get away with having my old ones trimmed down to a length where they wont bottom out??
Regards
Paul
Cut your original ones, or source shorter bolts.. Its up to you really!
I had the FK spacers that sat in between the wheel and the hub and bolted to the hub.
You need M14 x 1.5 bolts. Standard ones are 27mm for your reference.
16
14
715
30
6K
