EM TuningMonster Motorsport
Thread: Front Arm rest
    sprout99's Avatar
    Jun 2006
    North East - Dodge city
    367
    Front Arm rest
    Looks like my arm rest has packed in.
    Release mechanism is not working properly.
    Any suggestions on fixing it?
    How much is a new one?
    or should i go and sit down first?
    2004 AUDI A3 S-LINE DSG TDi
    MAURITIUS BLUE
    2005 BMW 120d M Sport 163+
    BLACK SAPPHIRE
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,052
    Definately try to fix it...
    I've seen a few posts in this forum about repairing/upgrading the various pitiful mechanisms in the armrest; a quick search will probably yield plenty of useful info... I'm sure there was a thread in the last month or two about such a task?
    Also, Definetely sit down for the replacement price... A dealer will charge the earth, www.vagparts.com are a bit cheaper - usually between 170 and 200 for the whole shooting-match depending on the upholstery - but of course you probably don't need the whole lot...
    Regards,
    Rob.
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    Fix the button, Defratos posted a guide on this very recently, it will take you 2hrs max.
    The unbreakable armrest button
    sprout99's Avatar
    Jun 2006
    367
    Quote Originally Posted by NEiLS3LK51
    the only bit i managed to get off was the cover around the bottom bit.
    i had a look for screws inside. Are they well hidden or something?
    MAURITIUS BLUE
    BLACK SAPPHIRE
    sprout99's Avatar
    Jun 2006
    367
    4 flocked screws were hidden!!!
    All done now. i used a 95mm long 4mm diameter steel rod
    Drilled right through button and a dot of super glue for good measure on inside.
    Just need to tighten nut under handbrake that is loose and causes rattle.
    (was being a bit rough last night)
    I'm a happy bunny now. Job took 30 mins to do using metal bar route.
    one of the advantages of being in an engineering environment.
    Thanks again to NeilS3.
    MAURITIUS BLUE
    BLACK SAPPHIRE
