Volks AutosEM Tuning
Results 1 to 9 of 9
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    Help on Brake pad replacement
    Hi, I have bought my EBC Turbo grooved discs and red stuff pads for the front. I was going to put it in and have a garage do it but thought I want to make sure the discs go on properly and everything is clean and tight. My question is around the replacing the pads, obviously they will need pushing out to allow for the new pads. so how do i do this, thanks
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    http://www.justoffbase.co.uk/s.nl;js...3&it=A&id=7397
    You will need one of those to push it back..you can pick one up in Halfords
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    I see, so you remove the pads let the tool pass through one side the large lip crosses the fixed part of the caliper and the screw head pushes the piston back, is that it?
    Any other advice from anyone or should this be easy?
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    remove the caliper you will see to indentations on the face of the piston were face of the plate does on ,the piston has to screw back in ,take the cap off the brake fluid res..as the fluid going back sometimes goes over the limit........remember clean the discs as they will have protective film on them ......Halfords will have that or factors
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Mar 2006
    london/ essex
    114
    make sure you takeyour brake fluid cap off so when you push the piston back fluid can rise up in side have a cloth around it as it will eat paint, and you should be able to push it back your self should be a bit stiff unless it is a wind back type then you have to turn it back.
    sneaky silver s3.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    isnt it just the rear caliper pison that need winding in ???? the fronts normally just push back in dont they..
    havnt done the S yet but all the other cars ive done have been like that.
    red to red black to black blue to bits
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Yes only the rears need winding back in, the fronts just push back.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    yes sorry my mistake the rear winding back (handbrake):D
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    All done last night, the pistons just need pushing in. The spring clips were the first things I removed then the retaining bolts needed undoing this freed the caliper enough to remove it and the pads. Once the caliper and pads were off I was able to get the discs out, however the caliper holder needed removing to get the new discs in. So everything got copper greese (except the disc brake face ;-) ) The new EBC GD930's went on, then the holders, then the calipers with the red stuff pads - one question, I did not find any cable to plug the pad into, so i cut the cable from the pad off (only on one pad so i guess later S3's had this sensor on one side, or should they all have it?
    The job was quite easy, however you will need a device of some kind to push the piston back in - i doubt you could just push it in by hand.
    Oh and while your at it you get a good chance to clean th einside of your alloy wheels, all very nice now!
