Badger5Sky Insurance
Results 1 to 11 of 11
    Scotland
    154
    Part Number for Door Lock Mechanism/Sensor
    I've started to see the door (drivers side) not closed display appearing on the DIS. From what I've read elsewhere on the forums this has something to do with the door lock mechanism?
    Does anybody who has experienced this fault have a note of the relevant part number.
    JohnS3's Avatar
    Oct 2004
    3,021
    Hi there,
    Had the same issue, bought a new one (part number 8L2837016) from Audi, cost about 45-50, can't remember the exact cost. It's a devil to fit as you have to strip the door and remove (or at least move to one side) the door glass and frame. You can actually fix your existing lock, but you have to remove it first. Then carefully bend the metal spring arm on the microswitch until you can here it click when the lock is in the closed position. I just wish I had taken some pictures.... Dohh!
    Regards, John.
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    Had this problem dealer changed the lock.. as mentioned you need to remove the trim and the glass
    Jun 2006
    92
    i get this problem but only when it's really hot outside!
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    Yep was the same with me
    Scotland
    154
    Thanks for the feedback guys, very useful
    regards
    JohnS3's Avatar
    Oct 2004
    3,021
    Hi Vikz, I forsee bad news for you...... My door lock started to do the same when it was hot, then it did it all the time so i had to change it. Hopefully you may be lucky!!
    Regards, John.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    It's actually not that bad to fix if you look at the other threads on the subject you can do it carefully but splitting the door in half. Took me less than an hour I think, the worst bit being disconnecting some of the cables from the latch.
    Jun 2006
    92
    at the moment mine is only giving problems in the heat but when it's been parked in the shade it's fine, touch wood.
    how much did the sensor cost you exactly?
    Jun 2004
    Crowthorne, England
    2,512
    I think the passenger one for my car was 38 from memory.
    JohnS3's Avatar
    Oct 2004
    3,021
    I think mine was 48 from Harrogate Audi.
