AH FabricationsChris Nott
Thread: helllp!!
    Mar 2006
    lincolnshire
    254
    helllp!!
    just pulled out of a junction went to change gear so put the clutch in and heard a crunch from the pedal, pulled over and some black plastic had snapped an a chunck of white plastic fell down, looks like a clip? now i have no clutch wats happend?
    Jun 2006
    10
    Hi
    Sounds like the ratchet self ajustment mechanism has bust.
    Is a guess as i have not looked to see if the A3 has this.
    If it is,then its not a serious problem,providing it did not break due to a clutch problem.
    Jaywoo_A3's Avatar
    Audi dead, 2.0T all the way!
    May 2006
    Swadlincote, Derbyshire, UK
    505
    Its a little plastic clip on the back of the pedal thats broke. happened to me one night when i was giving mine some beans down the lanes.
    Also had experience with it on my mates TT. The Clip was less than a fiver but you need to take the pedal out i think, cant remember as my mates garage did it for me?
    Audi A3,Facelifted, Porsche Cup 3 18" Rims, RS Style Front Bumper, Smoothed Rear Bumper, Lowered 35mm, Blue Flame Stainless System, S3 Grey Leather Interior, Xenon's.GONE!
    darko's Avatar
    Dec 2004
    london, uk
    272
    happened to me - its no biggie ! you need to replace the clips that broke off but you will also have to replace the clutch pedal - its not expensive. its a really naff design this one and i made sure it would never happen again on mine by having the new pedal welded before i fitted it. fitting by the way is a bit of a faff but just be patient. when you get the new pedal you will see where the old pedal has failed, a small piece of metal is folded over and tack welded to form a box section that pushes the clutch mechanism. the tack weld fails and causes the folded metal to bend and then snap off - the plastic clip holds for a while but then that fails too. let me know if you need a picture and i can look up the one where i had my pedal modified - if you do a search for my old posts you will find it too
