Results 1 to 9 of 9
    Bring on the Ice!!
    Jun 2006
    Edinburgh
    59
    tyre change and wheel alignment HELP!
    Hi folks,
    Im after a bit of advise,
    After some slippery experiences in the wet and examining my odd and differentially worn tyres i've decided for a change.
    I realise this would be the best oppotunity to play with the wheel alignment. EEs' report suggests a negative chamber of -1.0 to -1.5 and about 5 degs toe out (front).
    I have a number of questions really:
    Is this easy and cheap to do?
    How does this affect the tyre wear?
    is this effective at improving the handling when aligned with the standard S3 suspension set up?
    While doing all this are there any other alignment or related issues I should be awhere of or consider?
    thanks for any help
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    To get the best out of that sort of set-up you really need to be travelling in a way that the standard springs and dampners won't really allow. If you drive 'reasonably' hard the you keep the loaded tyre flat so wear isn't a problem.
    The alignment isn't a quikfit job, and most places that will do it will charge you about 90-150. I've been running with 4mins toe-out per side for a few thousand miles and no uneven wear. Wouldn't say it's too great all round, but really good in tight twisty stuff. I'm changing back to parallel toe next week.
    [/sarcasm]
    Aug 2004
    526
    Quote Originally Posted by ChriS3
    Could you elaborate on this please Chris (i.e. the all round comment), as I'm getting my alignment done tomorrow!
    Cheers,
    B.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Toe-out is good when cornering as the car likes to turn. Not so good when you're on the motorway when you have to hold it in a straight line at higher speeds. If you go with 0 toe, then the wheels are neutral and you lose less power through the transmission.
    [/sarcasm]
    icenutter's Avatar
    Jun 2006
    595
    In otherwords you don't have to have the standard settings. Suspension setup is always a compromise between grip/handling/comfort/tyre wear. The factory settings are fine, but you might want to go for something different if you want a different type of compromise (and i guess most people on forums such as this would want something 'sporty').
    Aug 2004
    526
    I had my alignment done today and the rear was way out. Car now feels much better (although still need some lightweight 18s). Much more stable at speed and far better cornering.
    As an aside I had this done at APS in Bracknell and can't recommend them highly enough after my experience today. Rear ARB drop links replaced and 4 wheel alignment for less than 80 (inc vat) all in. Friendly, loads of time to discuss the car setup, and showed me what they were doing on the car. Will definitely be back in the future.
    Cheers,
    B
    S3 AD's Avatar
    Jul 2006
    South east
    221
    I know my tracking to be slightly off & want to get the alignment checked on all corners as well, can you tell me were APS is in Bracknell please? as thats not far from me.
    Aug 2004
    526
    Quote Originally Posted by S3 AD
    oops sorry - too many stellas last night - I meant to type Brackley (northants). Sorry for the confusion.
    S3 AD's Avatar
    Jul 2006
    South east
    221
    no worries I know the feeling - can anyone reccomend some where to get this done in the Reading Bracknell area??
