Badger5Volks Autos
Results 1 to 10 of 10
    Jan 2006
    Glasgow
    51
    Pulling to the left!!
    When driving if i loosely hold the steering wheel my A3 seems to pull quite a bit to the left.I got new tyres fitted 6 months ago and i think the pressure in them is fine.
    What is the most likely problem that could be causing this??Balanced wheels or wheel alignment (sp) or along these lines.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Probably a wheel allignment - did they do this when you had the new tyres put on?
    i think kwik-fit offer a free check if thats any help
    Jan 2006
    Glasgow
    51
    Dont think they were mate.Just know the guy said that they were balanced.Just a case of popping into kwik-fit then you think?How much do they usually charge for alignment?
    Thanks.
    Aug 2005
    Watford
    54
    About 20
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,294
    My S3 still does this after everything set and checked correctly. I think it's just a case of mine tram lining and following the camber on the road, might just be that mate!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Aug 2004
    526
    Quote Originally Posted by DPM
    Same here - pulls ever so slightly to the left and always has done. I don't notice it anymore to be honest.
    Peloton's Avatar
    Jun 2006
    354
    I heard a while back that due to more bumps & pot-holes at the side of the road the left hand side of the car takes more of a beating (bushes, shocks etc.) hence making it run less efficiently. I don't know how much truth is in this but it sounds plausable.
    2000 Audi S3
    Aug 2005
    UK
    114
    I agree with the road camber theory. I have had my car setup and it still slightly pulls to one side occasionally, im sure this is down to the way that the road sits as it doesnt do it all the time.
    Aaron
    Audi S3
    210Bhp : Quattro : 19" New Style RS4 Alloys : Facelift Badges : 15mm Hubc Spacers on rear : Painted grill Surround : Aero wipers
    jamiekip
    I have the same problem on my s3. Camber on a road has it pulling to the left unless the road is perfectly flat.
    Had the car 3 years and get even wear on all tyres so nothing out of alignment.
    Jun 2006
    712
    mine does the same, just had 4 new tyres, and full optiflex at Audi and it pulls to the left on some roads, as has been said, most roads are flat and will pull you that way
