Volks AutosEM Tuning
Results 1 to 34 of 34
    Jun 2006
    298
    Oil Pump Failure
    Hi all,
    Has anybody had their oil pump fail? Or anyone replaced it? I've read a few threads on ukmkivs, and they seem to die around 100k miles. Mines at 98 at the moment, so this maybe an up and coming DIY job.
    Looks simple enough in Haynes, 4 steps after you remove the sump, basically undo the bolts holding it in place, release the pump sprocket from chain and refit. But the haynes manual gives it a 4 spanner rating!
    Symptoms from those Golf's affected include loud "tappet" sound from power steering pump/charcoal cannister, which mine has recently developed. Power steering seems fine, and don't know what the charcoal cannister does.
    Has anyone done this DIY job and can point to a how to? Or am I gonna have to do my own???
    Anybody shed any light?
    Cheers everyone,
    Andy
    Jun 2006
    712
    i'd be interested to hear the outcome on this one, mine has 96k and I dont think it has been done
    VaulterTim's Avatar
    In a world of my own...
    Aug 2004
    London
    74
    It's not majorly difficult if you know your way around an engine... bit fiddly because of it's location, especially if you'll be doing it on the floor! but other than what the manual says (which I'm unsure of to be honest because I've not read it!) it shouldn't cause you any major problems... the sprocket is physically bolted to the pump so undoing the bolts is all that is required to remove it. Actually getting it out of the chain may be a bit fiddly but if you've removed the tensioner you'll should manage ok. Just be careful with the tensioner because it's plastic!
    One thing I would look out for on a car with your mileage is the condition of the sump bolts themselves. There are quite a lot of them and if only one seizes or has a dodgy head then you won't be able to get the sump off. Just take care when removing them and make sure they are as clean as possible before trying to turn them.
    Hope that's of some use...
    T
    Info Sponge
    A4 1.8Turbo Quattro Sport | 18" RS4's | RS4 Front Grille | RS4 Front Bumper | Forge FMDVR | Milltek | AmD Remap | Lots of other naughty bits waiting in a big box...
    PaulS3's Avatar
    UK
    988
    tappety sound from the charcol filter is normal.
    it is recylcling the fumes from the petrol tank and burning them off in the engine.
    the tappety sound is the solenoid valve opening and closing to regulate the release into the engine.
    Audi S3 Quattro Black Edition.
    Aug 2004
    526
    So what is the consensus then? Is this a potential problem and worth doing on higher mileage cars as a precaution? My S3 is at 86K and so I too would be interested in this.
    Has anyone had an oil pump fail on an S3 or heard of it happening?
    VaulterTim's Avatar
    Aug 2004
    London
    74
    Post
    Not the pump itself under normal conditions but I saw the results of a high power S3 (400BHP+) snapping the chain tensioner and consequently getting caught in the oil pump pickup recenty...
    God only knows how it got in there though... given the strainer graduation! :eek:
    Info Sponge
    VaulterTim's Avatar
    Aug 2004
    London
    74
    Any more on this?
    Info Sponge
    sprout99's Avatar
    Jun 2006
    North East - Dodge city
    367
    this happened to a lad who i work with (he drives A4 sport 1.8T)
    4 new pistons later all is ok !!
    2004 AUDI A3 S-LINE DSG TDi
    MAURITIUS BLUE
    2005 BMW 120d M Sport 163+
    BLACK SAPPHIRE
    Jun 2006
    298
    Oh dear!! No more news, new pump is 85quid though. Looking at doing mine next weekend hopefully.
    Feb 2005
    Glasgow
    76
    My oil pump went at 80k although the oil pressure light came on periodically from about 65k but gradually got worse. I got it done by a garage which was about 140 inc labour.
    Jun 2006
    712
    I think i'll be getting mine done at my next service then!
    Aug 2004
    526
    Quote Originally Posted by alecblack
    What car was this on Alec?
    Were there any other symptoms apart from the warning light, such as a louder tick over from that side of the engine? Mine has just sounded a bit louder over the last couple of months as described at the start of this thread, and intermittently there has been a much louder tappety sound (used to the charcoal filter sound so it's not this I don't think).
    Cheers,
    B
    Feb 2005
    Glasgow
    76
    Bantam1,
    I drive the TSport
    It was only ever the warning light until the very end when I drove it home one night it sounded like I was driving with no engine oil, I never drove it after that until I got the oil pump changed.
    Jun 2006
    298
    Well I got the pump changed last week and looking at this thread
    http://www.pistonheads.com/gassing/t...78372&f=86&h=0
    I'm glad I didn't leave it any longer.
    GET YOURS DONE ASAP!!
    Andy
    Aug 2004
    526
    Quote Originally Posted by LaSarthe&Back
    Andy
    Did you do this yourself Andy or get it fitted by a specialist? How much did this cost in total?
    Don't know what to do now as wasn't aware this was a problem before with 1.8Ts until this thread.
    Cheers,
    B.
    Jun 2006
    298
    I got it done buy a garage who did my cambelt before I first bought the car.
    190 all in. Pump itself is 85 from stealers and fitting requires dropping the sump off and swapping over.
    It seemed like quite a simple job, but Haynes gives it a 4/5 difficulty rating, so decided to stay clear. DIY'd my cambelt and that was hard enough at 3/5!!
    Andy
    Aug 2004
    526
    Andy
    Was the garage able to comment on the condition of the old pump and has the tappet sound you originally described gone now?
    Cheers,
    B.
    Jun 2006
    298
    I had the old pump back, and to be honest it didn't look at all bad. It still rotated smoothly and didn't seem impeded in operation at all. That's not to say it wouldn't have spontaneously packed up.
    The oil pick up line, however, was cloggedwith sh!t. All small particles etc. I'd say it was about 40% blocked. Never had any oil warning lights at all.
    The line that comes out of the black (power steering??) pump, perpendicular to the line where the bonnet meets the wing was pressured and I could feel it pulsing about 2-3 times a second before I had it replaced, and now it is completely smooth and not pulsing whatsoever.
    It went in on thursday and I haven't heard the tappety sound coming from where it was since before it was done. So I feel confident it's sorted. Don't mistake the sound from a similar one which should come from the engine.
    I would say that it's more the pick up line that will cause the problems, but the pump may as well be done while the sump's off for the sake of 85 vs 1,000's for serious engine damage.
    Let me know what happens with yours if/when you have it done.
    Hope this helps,
    Andy
    mnadeem1984's Avatar
    Jul 2005
    Birmingham, UK
    76
    i had my pump changed in April 2006. After about 2 hours, the warning light came on again. Took it to another garage, they said it was the pick up line, Cost me 90 pound to have it removed and cleaned. Today, after booting the car a little around town, once the oil was hot, same thing. The oil light comes on. If you continue to drive the car, the engines goes loud and sounds like a diesel. I gave the garage a call, they said its likely that the pick up line is blocked up again. I just bought a new line for 7.25 from the dealers. Gonna fit it tomrrow myself.
    One thing thats scaring me. After this problem, i left the car for about an hour to cool down. I then drove the car around 7 miles (never booted it though). The car ran fine. No oil light came on. Can this be the pick up line which got blocked because it picked up some dirt, or is it possible that the oil pump (dealer part replaced in april 2006) is playing up?
    A3 1.8T 2000X AUM,
    ECU Remap,
    Jetex Full Through Exhaust,
    Uprated Forge DV,
    Pushing 218 BHP
    Jun 2006
    712
    i've decided, a new pick up line and a new oil pump for mine.... at 97k, I think its a good idea!
    Jul 2005
    Birmingham, UK
    76
    I did mine yesterday. Although i didnt have to replace the oil pump this time (it was replaced in april this year), the pickup pipe was replaced. (Between april and now, i have had three oil changes and still the pipe gets clogged!).
    Anyway so far, so good!
    A3 1.8T 2000X AUM,
    ECU Remap,
    Uprated Forge DV,
    Pushing 218 BHP
    KEF A3 20V T's Avatar
    Turbo's Rule
    Sep 2006
    Whitby
    198
    does the oil pump have to be timed to the engine? do you use good quality oil? what kind of stuff bloks the pickup pipe? is it a black gloopy substance?
    Aug 2004
    526
    The terminology is confusing me here - are people talking about the same thing when they say oil pick up line and oil pickup pipe. I have had the "oil strainer" changed on mine, which I took to be the same thing. Is that correct?
    Cheers,
    B.
    Jul 2005
    Birmingham, UK
    76
    yeah the line is the same
    A3 1.8T 2000X AUM,
    ECU Remap,
    Uprated Forge DV,
    Pushing 218 BHP
    Turbo's Rule
    Sep 2006
    Whitby
    198
    what type of substance was blocking it? i seems odd its blocked twice?
    Secret Squirrel's Avatar
    Sep 2006
    In the Westcountry
    185
    No problem with my oil pick up pipe/line when I last checked it at ~120k miles.
    I use only good quality synthetic oil which gets changed regularly, and the car always gets regular long blasts. If that helps.
  28. #27
    Turbo's Rule
    Sep 2006
    Whitby
    198
    it is ov odd the pickup line/pipie getting blocked in mnadeem1984's engine in under a year! when e3ngines can do 120K and still be fine! i know in diesel engine soot can form in engine and the causes a black sludge which can obstruct oil flow. but soot isnt normally a problem in petrol engines unless there is a leaky piston ring or a rich fuel mix! vbmenu_register("postmenu_260554", true);
  29. #28
    Turbo's Rule
    Sep 2006
    Whitby
    198
    hey i found this i think the part about a quater of hte way down the page may be of some use! it talks especialy about the 1.8t
    http://www.carbibles.com/engineoil_bible.html
  30. #29
    Jul 2005
    Birmingham, UK
    76
    it had two or three granule type of things (looked like rice or something). I also found some excess sealant which the company used last time to seal the sump. I aint driven the car hard yet. Gonna try tomorrow to see what it does.
    A3 1.8T 2000X AUM,
    ECU Remap,
    Uprated Forge DV,
    Pushing 218 BHP
  31. #30
    Jul 2007
    85
    Hi,
    I have a Audi A3 1.8T and a couple of month's ago I had a problem with the oil light turning on.
    The oil level was Ok, the car went to be repaired and since then the ligth came on twice and then never came back again.
    I made a search on the web, found this thread and since my car is almost at the 99K miles I'm worried.
    My engine is a AGU and I would like to know if I should replace the Oil pump or not ? Does this problem happens with all the 1.8T engines ?
    Thanks in advance for your help.
    Regards
    Luis
  32. #31
    Jun 2006
    712
    Quote Originally Posted by jonS3
    7 months later I finally got it changed. I had no symptoms or reason to change it apart from preventative maintenence. I had some other work done so thought i'd get it all done at the same time.
    My S3 had done 103k at the time and the original pump and pick up looked fine, no visible wear or gunk build up, but then I have changed the oil 5 times in 12k
  33. #32
    Jul 2007
    85
    So, what should I do ?
    Replace it ? Or leave it ?
    I change my oil every 5k miles, I guess it wont get very dirty
    with that mileage.
    Can anyoene provide the part numbers of the oil pump and oil pickup line ?
    Thanks in advance.
    Luis
  34. #33
    Jun 2006
    712
    it's up to you, worse case scenario is that it does fail and you get a warning light, in which case turn your engine off immediatley and get it recovered. I did it for piece of mind/out of interest/and a good selling point IMO.....
    if you;re doing it yourself get the prices etc from your local audi dealer, and it not then get the garage to quote all in.
    you will need to change oil pump, pick up pipe, sump bolts, and will need new sump liquid gasket, but be careful with that as if you put too much around the sump it could dry and get picked up by your pump......
  35. #34
    Nov 2008
    95
    my s3 is doing the same thing! I does supose any of you have the part number for the oil pick up line? as my audi are rubbish!
