Volks AutosSky Insurance
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    Can anyone tell me what these fault codes are please?
    Hi there, got these fault codes up today, after thinking to myself, i've never had a car that hasn't given me a problem for 8 months before, something must be wrong. I'm using the shareware version of vag-com and this is what it's given me, wondered if anyone can decypher this mumbo jumbo please?
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Skipping Address 15-Airbags
    Address 35 -------------------------------------------------------
    Controller: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 13130
    Shop #: WSC 06313
    5 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01374 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    01370 - Shareware Version. To Decode all DTCs
    00955 - Shareware Version. To Decode all DTCs
    09-00 - Please Register/Activate
    01134 - Shareware Version. To Decode all DTCs
    49-00 - Please Register/Activate
    cheers lads,
    Ross
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    your alarm has gone off a few times in the past and you may have a air leak on one of the locks/pump or pipe
    clear all the codes and rescan in a few days and see what if any codes come back
    its just an old estate (well a 500bhp estate anyway)
    PaulS3's Avatar
    UK
    988
    I cant be bothered to do the leg work, but in future you should be able to look most of them up on here.
    Or upgrade to the full version of vagcom ;o)
    http://www.bentleypublishers.com/tec....dtc.table.htm
    Audi S3 Quattro Black Edition.
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    Does the shareware version allow you to delete fault codes? I wonder what B@stard is setting my alarm off.. I may attempt to set up the car so the horn goes off with the alarm cos i've never witnessed it going off! hmm thinking about it i may have locked the doors with one door open at the field the other day..
    peteA3tdi where did your source your fault codes from? as the other persons code list didn't have any of my faults on it. cheers
    Ross
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    Bump for finding out where pete gets his fault codes from. Also, how much is it to upgrade to the full version of vag-com? cheers
    Ross
