Someone else might know. But you should be able to see it...its stamped on the engine, left hand side I think. You may have to remove the engine cover.
Just in case you haven't got your hands dirty yet... You can also get your engine code from your Vehicle Data Sticker(s) - you should have two.
One is normally stuck to the inside front-cover of your service record; the other is normally stuck inside the spare-wheel well in the boot (most likely rear-right corner (in effect nearest your right-knee as you peer into the boot)).
