Chris NottJMB Retrofits
    Oct 2004
    Chassis number cover
    Can the perspex cover over the chassis number on the bulkhead be replaced. Mine has completely disintegrated and at a cursory first look it seems to be attached fairly well (what's left of it) to the surround.
    Not a very excitng question, but any help appreciated.
    Thanks.
    R.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Mine also .... popping into dealer soon so will ask (they are pretty clued up so expect a reasonable answer).
    S3(225) - Dolpin Grey | Leather/Silver Alcantara | Bose | ViperDV | Samco Hoses | Eibach Pro-Kit | H&R Spacers | Brembo GT kit | AreoWipers | BlueTooth | Dension Icelink | New engine, Clutch, Turbo, Water pump thanks to Cambelt @ 79,000 miles | New short engine thanks to ****ed valve 22,000 miles later!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I suspect you will have to replace the entire plastic scuttle panel. 35 from memory?
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    concoursneil's Avatar
    Aug 2003
    Plymouth UK
    327
    Def scuttle panel replacement , the new one will do just the same over time.
    Better off trying to trim it off really neatly and possibly cutting a proper bit of thin perspex and fitting it in the same place.
    Oct 2004
    Thanks for the ideas, 35 isn't too bad for the whole panel, but a bit steep for a 4" bit of perspex. Might try the Blue Peter method first.
    R
    davidhodgkinson's Avatar
    lancashire
    198
    Just replaced mine as well, the clear window is def. bonded to the scuttle panel.
    Was A3 1.8Ts
    Now S3
