Chris NottAH Fabrications
Results 1 to 13 of 13
    Nov 2005
    London
    29
    Exclamation Dump Valve - A3 Turbo
    Hey all,
    I bought an A3 1.8 Turbo and it came with a dump valve, which makes alot of noise
    However, i think ive decided to take this dump valve off and maybe sell it on ebay or anyone here that wants it?
    To replace it will i have to go to an audi dealer and get a normal dump valve? and does anyone know how much they cost?
    Any info you can give me is much appreciated as i have never had a car eith a dump valve before
    A
    Jun 2006
    135
    I think they use the standard BOSH DV, only about 12 or so.
    Do you know if the one on these is a Bailey or a Forge?
    If its a Forge I would leave it on.
    Audi A5 2.0TFSI 211 S Line
    Lotus Evora
    Nov 2004
    Tonbridge, Kent
    912
    I would imagine if it is making a lot of noise it will be an atmmospheric one rather than a recirculating one. Get the part from vagparts.com as they are cheaper than a dealer. Or get a piston recirculating one like a Hyperboost or AMD Viper one.
    Nov 2005
    London
    29
    Hi, im not sure if its a baily or a forge. I will check tonight.
    Its definately an atmospheric valve as it makes alot of noise and ive been told it hurts performance. Sometimes you can feel the lag.
    Any ideas what i should replace it with?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,285
    I'd get a Forge 007 or Eliminator DV. Cost more then a standard but alot better and i'm sure we could do you a deal on one!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Mar 2006
    lincolnshire
    254
    ive been given a bailey dump valve are they any good?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,285
    Not the best to use on the VAG 1.8T's... More for Evos, Cossies and Skoobies!
    DPM Performance
    T: 01207 561606
    rich1068's Avatar
    Jun 2006
    Sheffield
    673
    Another vote here for the Eliminator DV. Very quick response and no servicing.
    A3 2.0T FSI Quattro S-Line
    Gone...and quite quickly forgotten
    robthehungrymonkey's Avatar
    Apr 2004
    Uckfield, Near Brighton
    555
    I've got a Forge 007 for sale if you want it?
    Let me know.
    Westfield SEiW - 2.0 16V XE power
    Volvo Wagon - 1.8 Volvo power!!
    Nov 2005
    London
    29
    Hi Guys,
    I can get the standar dump valve for just over 15. How much are you guys selling the Forge 007, and is it wise to by a second hand one?
    Also, will my mechanic be able to fit it in, i know its a stupid question, but when i mentioned it to him he dodnt know what a dump valve was
    Apr 2004
    555
    I was looking for 50 for it. It hasn't been used much, and it's immediately obvious how and where to fit it. (I sent you a PM - check your inbox)
    I'm about as far from a mechanic as you can get!
    The standard part that cheap? Where from? I thought they'd be really expensive.
    The forge one is also servicable, and you can open it up to clean it or put a new spring in etc. The standard one is black plastic which you cannot open easily.
    I can't see any reason not to buy 2nd hand as the main part is just metal, and the inside there's just a piece of plastic, a bit of rubber and a spring - all of which I have spares for.
    rich1068's Avatar
    Jun 2006
    Sheffield
    673
    If your car is mapped then go for the Forge. If it's standard just use the Audi part.
    Re: buying second hand. No problem at all. Ring Forge and tell them you've got a 007 and they'll send you a service kit FOC. Service kit comprises of a new piston, rings and grease. Watch what spring is in the 007 though, people seem to like the stiffer yellow spring but I found them a bit harsh for my driving. If you want to change the spring Forge will charge you for a replacement.
    If you have set your heart on a DV though, as I already said I do recommend the Forge Eliminator.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,285
    Eliminator will give you better throttle response even on a standard car and it also doesn't need servicing!
    DPM Performance
    T: 01207 561606
