EM TuningChris Nott
    Jun 2006
    A3 1.8T sport - bad idle and stalling issue
    Hi guys
    Me and the missus recently bought a 5 door X reg 1.8T A3
    very impressed with the car, even if it is our 'runaround'
    BUT
    last night some strange things happened.
    when left to idle, it would just stall
    then on restarting, if I didnt feed the throttle to maintain revs.. the revs would wander / hubt.. then the car would die.
    I gave it a bit of a blast and it seems to have solved the stalling issue, but the idle still hunts a bit
    any ideas??? / sensors to check or clean up?
    thanks
    Dave
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    Sounds like a air mass (MAF) issue, if you know what it is/where it is disconnect the plug and see if it runs any better.
    VERY common across all audi's
    Jul 2005
    2,488
    usual things to check, coolant sensor, lambda probe and give the throttle body a clean.
    Jun 2006
    cheers guys.. anyone know where the MAF sensor on a 1.8T engine is?
    im assuming the intake to the inlet manifold ?
