Monster MotorsportVolks Autos
Results 1 to 8 of 8
    thinking about stuff
    May 2006
    Leeds
    599
    How to tell if the MAF is faulty
    done a search for "MAF" with no results. I've got a revo'd 2001 S3 which sometimes goes like stink but other time you can plant you foot and you just don't get that kick as it comes on boost. The acceration also doesn't always feel even in gear. Like the delivery is spikey. Does this sound like a MAF thats dying? Is there any way to confirm it or just a case of buy a new one and hope it cures the problem. How much doe they cost, is it a straight swap or do you have to go to the dealers for a any codes resetting.
    thanks in advance
    2001 Black RS4 - P11 LCC
    1992 Burgundy Pearl Corrado VR6 - A20 LEE
    nwhiteley's Avatar
    Jun 2006
    Howfen (its in Bolton)
    195
    to test the maf, just unplug it (its between the airfilter and the engine), and if performance improves, change it
    the cost depends on where you buy it from. about 90 from the stealers.
    most of the time they dont show an error code and thay are straight forward to fit.
    another cause could be heat soak in this rather hot weather we are having at the moment
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    9 times out of 10 its the MAF,like nwhiteley said, unplug and see how it goes, or if you have vag com see what kind of readings you get from it.
    I'd just take it to AmD tbh.
    May 2006
    Leeds
    599
    Quote Originally Posted by Olly_K
    I'll unplug tomorrow and go for a spin. What difference should i expect from unplugging it. I know that my corrado doesn't idle with it unplugged, Not a fan of AmD.
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    well, everyone has their choices, I personally get a great service from AmD
    Jul 2005
    2,488
    I think it goes something like:
    if you unplug it, and it runs the same, it's probably knackered.
    if you unplug it, and it runs like crap, its probably OK.
    dont forget to take into account the warm weather we're currently experiencing. The intercoolers on s3's were audi's idea of a joke, to the point where in hot weather an s3 can sometimes feel like a stock 1.8 NA....... the throttle response can be shocking.
    Sep 2005
    West Midlands, UK
    141
    Quote Originally Posted by leecs3
    On my TDI, it was no different with the MAF unplugged- it *should* be much flatter. Replacement MAF makes the car feel much quicker.
    The best test is a 'drive it like a hire car' run with VAG-COM logging.
    Nov 2005
    lothian
    181
    Whats the maximum flow for a MAF for a std 110 tdi 98 in VAgcom?
    Thats normally how you tell if they are goosed on the S4.... for std you should see around 215, modded 230 and up.... if it reads low then its normally goosed....
