EM TuningMonster Motorsport
Results 1 to 9 of 9
    Jan 2005
    Midlands
    31
    Help! Immobiliser Problem - Car Won\'t Start
    Hi Guys
    Upon trying to turn my key in the ignition, the car turns over for about a second and then cuts out.
    The Immobiliser amber light continually flashes on the dash. I initially presumed it was an issue with the key fob battery (although it still remotely opens the doors on the car), so I decided to try a spare key that I have, but again the same issue! The car simply turns over and just cuts out.
    Any ideas how to resolve this one?
    Any help would be great, I dont like walking...
    Ad
    Jun 2003
    World of my own
    9,813
    Re: Help! Immobiliser Problem - Car Won\'t Start
    Adam you have mail
    jayfrts's Avatar
    bouncing off the limiter!!!!
    Apr 2004
    Herts
    92
    Was this error resolved?!?!?!
    "Development is only necessary to rectify the ignorance of designers" -Keith Duckworth
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    help
    Ive got the same problem
    just removed all my rnse, BT and phatbox as swapping car.
    It worked fine until I removed the intrument cluster to take out the gps antenna
    Can anyone give me some ideas
    HELP
    Jun 2004
    Surrey
    595
    Any pins bent? Connectors in properly? No damaged wires in any of the connectors?
    Aug 2005
    staffs uk
    351
    No
    I actually drove it with everything removed apart from the gps anntenna.
    Removed that and now this problem
    I'll just going to remove the clocks again to see if there is any bent pins
    be back in a min
    Simon
    just removed a nd refiited clocks, no bent pins
    same problem, immobiliser light flashing. tried moving sterring column up and down and in and out but still the same
    anyone any ideas???
    cheers
    simon
    Aug 2005
    staffs uk
    351
    all sorted
    bad connection on back of ignition barrel
    cheers for the help lads, invaluable as ever
    Simon
    Jun 2004
    Surrey
    595
    Glad you got it sorted. What are you getting next?
    Aug 2005
    staffs uk
    351
    Ive got an A6 2.5tdi quattro Sport 180 coming this week
    miss the power of my previous 2.8q compared to the 1.9tdi now.
    Problem is in the A6 the 1.9 doesnt come in quattro. Big mistake not having it as all my previous Audis, right back to my first A6 2.8Q coupe have all been quattro
    Once you've had a quattro you never look back
    thanks for everyone help
    searching the forum and this post help me sort it
    Simon
