Chris NottSky Insurance
Results 1 to 10 of 10
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    Gear box, Air con console, & aerial questions
    Hi guys wonder if you could help with a few things,
    1. I intend to replace the gearbox oil when my car goes in for a service, roughly how much will this cost ?
    2. My + - tempreture button on the climate control console has been scratched & the black coating was removed is it possible to replace this ?
    3. I ve ordered a new areial base from VAGPARTS, i think i understand the procedure to install the new one. Should i use a sealant to seal it between roof & aerial base if so whats best ?
    Any help appreciated,
    Matt
    Nov 2005
    UK
    1,688
    Re: Gear box, Air con console, & aerial questions
    May 2003
    Surrey
    95
    Dunno about 2 and 3 but the mechanic I was chatting to at my service last week said the gearbox oil is life long.
    Nov 2005
    UK
    1,688
    Fair enough but i ve read on here that changng the oil makes the world of diffference
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    If you were having a problem with the gearbox changing the oil to a different type may make a difference,
    you use no sealer for the aerial just the gasket that is supplied
    Nov 2005
    UK
    1,688
    gearbox is fine its jus seems a little notchy. no sealer at all ? thought you would use something.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Gearbox oil change is simple if you have the tools and somewhere level to do it, 2.6 litres of oil are needed for the S3 and it is worth changing regardless of what Audi say - made a big difference on my car when I changed it to Motul of the same spec. I don't think it should take very long so I guess it's 30 mins + parts if that at a main dealer.
    Nov 2005
    UK
    1,688
    Motul being a brand of oil right ?
    Jun 2004
    Crowthorne, England
    2,512
    yep... check out www.opieoils.co.uk and you even get a discount for being an AS.net member, the motul oil is a bit on the pricey side though.
    Nov 2005
    UK
    1,688
    And as for the aerial base surely i should use something (sealer) ?
