Results 1 to 10 of 10
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Exhaust metallic resonance/drone
    All,
    Since the gear-box has been put back in my car, the car now has a metallic resonance/resonating/buzzing sound on over-run...at exactly 3400rpm, as the revs fall. Car needs to be warm, and in 2nd or 3rd gear for the sound to be prominant. It also seems to be louder when cornering left, but never occurs when cornering right.
    It sounds to me like its the exhaust or a heat shield or something!
    I don't think it is gearbox related, as gear changes are fine, no vibrations through the gear stick.
    Any ideas?
    AL
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Exhaust metallic resonance/drone
    Check the heatshields for the exhaust from downpipe all the way back... dont necessarily follow your ears as they can mis-guide you!
    Have a look around everywhere that would have been disturbed for the 'box to come out/
    Rich
    AL_B's Avatar
    1,564
    Cheers Rich
    Hopefully the weather will hold off for the weekend.
    AL
    ...Watching you!
    Earlsfield, London
    5,087
    Don't hold your breath! Mind you, might need to if it keeps raining!! [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Agree - heatshield .... happened to mine. A bit of 2"x1" is good to push and reshape it out of the way.
    Oct 2005
    cheshire,north west england
    71
    AL l have the same metallic sound on mine but at about 2400rpm.I believe its ok to to remove the heatshield and this hopefully will solve the problem.
    Does anyone know if this is correct?
    darko's Avatar
    Dec 2004
    london, uk
    272
    probably best not to remove a heat shield on turbo cars as the exhausts run so hot - i had a lot of problems with one integrale before and it turned out someone had removed a heat shield, the knock on effects were a nightmare !
    Oct 2005
    71
    what kind of knock on effects Darko id be interested to hear [img]/ubbthreads/images/graemlins/smirk.gif[/img]
    darko's Avatar
    Dec 2004
    london, uk
    272
    from memory (which is a bit hazy these days..) 2 electrical sensors expired early causing over fuelling (which was luckily caught early) a rubber oil return pipe went brittle and cracked due to being blasted by heat (the integrale turbo regularly was glowing bringht orange !) it also caused a hand brake cable to seize which was how we found the problem as we kept replacing them. there were a few other problems which, although never directly could be linked to the gaurd missing could easily have been caused by excessive heat
    AL_B's Avatar
    1,564
    Thanks for the suggestions.
    I didn't get round to checking the car, had to do the garden instead - shifting a ton of gravel by just buckets.
    I'm sure this has been asked before...whats the best place put the axle stands?...Don't want to damage anything.
    S3_MCD,
    Which heat shield was it for you?
    AL
