Results 1 to 20 of 20
    Sep 2005
    UK
    16
    Camber adjusters
    Does anyone know anything about H & R's Triple C Eccentric System. Looks like a cheap fix for excessive negative camber.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: Camber adjusters
    For the front or back?
    You need to add more to the front...not reduce it.
    And I can't see any form of eccentric system removing enough rear negative camber to get the rear suspension where it needs to be after lowering...
    Got a link to some details?
    Dec 2005
    Norfolk, UK
    24
    Hi,
    In an attempt to achieve the factory set-up I also found these the other week on the web:
    http://www.performancealloys.com/low...ts_springs.asp
    (Scroll down the page a bit)
    I enquired as I also though that these might be a good fix for achieving the correct rear camber - rather than go for adjustable tie arms - which seemsed a waste for my car with standard ride height.
    However, I was told that "The Tripple C adjusters are for use with Mcpherson strut suspension, so are only used on the front of vehicles or vehicles equipped with Mcpherson struts all round - I dont believe that the S3 has these on the rear, so the Tripple C system would be of no use unfortunately."
    There are also some Eibach adjustment parts (Eibach Alignment Kit) which seem common in the states especially on the TT. Eibach are currently looking into whether they are suitable for me or not.
    I will report back when I get a reply
    RGB
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    [ QUOTE ]
    Hi,
    RGB
    [/ QUOTE ]
    These look interesting ... look forward to your update.
    [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    No, they won't work. as you probably know by now.
    [ QUOTE ]
    [/ QUOTE ]
    ..and the McPherson strut needs to be of the two bolt flange type...rather than the type used in the S3 where the strut sits inside the hub, held by a pinch bolt.
    These could be used on a Mk3 Golf...for instance...but not on an A3/S3.
    Wrong fxing type completely.
    Out of interest, Mk1 golfs have camber adjustable bolts standard...so you can grab some from a breakers instead of paying H&E prices for these things...assuming you have a car they are suitable for!
    Sep 2005
    UK
    16
    How about ECS Tuning? They actually make a eccentric bush kit (Rear) for audi TT's. I can't see why these can't be used, although I'm not sure why 4 would be required as opposed to one for each control arm.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    I can't think you'd get enough adjustment on eccentric bushes...you need quite a lot of adjustment to sort out the rear camber.
    I expect two per side to allow one arm (upper) to be lengthened whilst the other (lower) is shortened...to try to get the camber back in line.
    Who knows though...
    The Forge solution works...and works well...so why risk it?
    Feb 2004
    UK
    1,320
    Glen,could you tell me your stage by stage handling upgrades again mate;
    1)springs/shocks
    2)+ adj rear tie arms
    3) +arb's
    Is that it?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    [ QUOTE ]
    1)springs/shocks
    3) +arb's
    Is that it?
    [/ QUOTE ]
    And a fair few hours/days playing with geometry settings until it all worked!
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    Lowered springs
    Suspension angles
    Tyre pressures
    18" wheels
    Tyre pressures again
    Dampers
    Suspension angles front
    Tie bars
    Suspension angles rear
    ARBs
    Feb 2004
    UK
    1,320
    thanks mate,
    what suspension angles do i need?
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Works well with 4 mins toe-out and as much neg camber as you can up front (about -1.3), and about -0.7 camber at the back.
    Feb 2004
    UK
    1,320
    Would you agree glen?
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    F as much as you can as Chris says...-1.5 each side if you can (maybe mod the ball joints a bit!)
    R I found -0.5 worked well.
    Front toe between 2 and 4 minutes total toe out.
    Rear toe set back to parallel.
    Feb 2004
    UK
    1,320
    Thanks mate
    Sep 2005
    UK
    16
    Seems a bit tiresome to beat on about the same topic....but..has anyone tried jabba's adjustable control arms which seem half the price of Forge's?.....
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    I believe they're the same thing, although I think the Jabba ones are exchange items (you give them your old arms - they mod them and sell them on).
    The ECS ones are the same too, but I think they're the most expensive......Rich???
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    So which are better ECS or Forge? Heard that Forge ones corrode quickly?
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Some of the paint on my Forge arms started flaking quickly, but I live in Aberdeen (rust capitol). The coating seems to be the same as the standard Audi arms.
    I've never seen the ECS arms, so I can't comment. RichA3Turbo should be able to help you with that...
    Sep 2005
    UK
    16
    Another thing was the MOT. Do the adjusters need to be approved by some transport agency to pass the MOT and being a modified part do they affect the insurance?
