AH FabricationsChris Nott
Results 1 to 20 of 20
    Apr 2003
    s.wales
    363
    DIS Showing Door Open But Its Not
    I've had this intermittently for a while now. The DIS is showing the door as being open when it is closed. This then won't switch the interior light off and when stopped, won't allow you to set the alarm with the fob.
    My brother (Audi Tech) says its a faulty micro switch on the door catch.
    Anyone else had this ?
    Chris.
    imported_Stewart
    Re: DIS Showing Door Open But Its Not
    It is a faulty microswitch, mine does it on hot days..
    Apr 2003
    s.wales
    363
    It seems to be worse on hot days too.
    Did you change yours ?
    Chris.
    imported_Stewart
    Not yet, i got a refurbished one off ebay, its not annoying me enough yet to spend half a day stripping the door down...
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    It's pretty common, can do wierd things... my interior lights would pulse and the car would lock but it would go off a few mins later.
    It's not that hard to do and only takes max 2 hours if your careful - you don't need to seperate the door from the car just the inner frame from the skin there a thread or ten on here with what you need to do too.
    imported_monkeytrousers
    [ QUOTE ]
    Chris.
    [/ QUOTE ]
    You bet - a very common fault. I got mine replaced under warranty.
    Not only was it irritating, my concern was that the car wasn't properly alarmed, not sure if that was the case though.
    hamski's Avatar
    Sep 2005
    UK
    116
    I've got the same with mine. DIS shows door open and interior lights come on over bumps and round corners.
    C_Audiboy's Avatar
    Vroom Vroom
    Nov 2004
    Glasgow
    811
    [ QUOTE ]
    [ QUOTE ]
    Chris.
    [/ QUOTE ]
    [/ QUOTE ]
    I don't think the car will be alarmed properly as it thinks the door is ajar. When the same problem happened with mine the red LED on the door would not light, but the remote would still lock the doors. All the more reason to get it fixed.
    Mine was replaced under warranty too [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    Apr 2003
    s.wales
    363
    Mine's out of warranty. Stewart, how much did it cost you ?
    Chris.
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    anyone know any old threads where this problem can be fixed?
    imported_Stewart
    It only cost me a fiver off fleabay, the guy had bought a brand new one then fixed his old one...
    Sorry I havent looked too closely at it but its something to do with the microswitch itself...
    I got the whole lock mechanism with the switch built into it...
    Maybe he stripped the switch down and repaired it, i dont know, sorry.
    Jun 2004
    Crowthorne, England
    2,512
    A quote from me in another thread...
    [ QUOTE ]
    these two posts cover pretty much everything, I was going to do a better write up, but my camera was being a pain on the day that I actually fixed it.
    http://www.audi-sport.net/ubbthreads/sho...true#Post340661
    http://www.audi-sport.net/ubbthreads/sho...true#Post337282
    the other problem is there is no real point in listing the part numbers because it'll be different for each side and could be different for different cars, however Audi seem happy to help and gave me the right part.
    [/ QUOTE ]
    And if they don't clear things up a quick look on the below might answer any other questions but if not just ask.
    http://www.audi-sport.net/ubbthreads/sho...true#Post338516
    http://www.audi-sport.net/ubbthreads/sho...true#Post345088
    hamski's Avatar
    Sep 2005
    UK
    116
    I finally had the driver's door sensor replaced. But the DIS still does the same!! anyone got any ideas??
    Golf Mk2 16v
    RS4 Cab
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,285
    Mines also doing this now, so annoying!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    JustSports's Avatar
    Jan 2007
    Manchester
    88
    I had this when i first bought my car, this is going to sound stupid, but i closed the lock with my finger with the door open, then reopened the lock and then shut the door ! its been fine since !
    I think the lock just gets stuck, especially on hot days, perhaps just needs some grease / wd40 ??
    QUATTRO_REP's Avatar
    Diesel Power!
    Oct 2006
    Manchester
    228
    i had this last year, and yes it pissed me off a great deal with the interor lights being on after the car was locked and no alarm being on. i just hammered the door lock mech with WD40 and i havent had any trouble since. the hotter days really did make it worse tho.
    Audi A3 52 | 1.9TDI Quattro | Chipped 175 BHP | Hids |
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Quote Originally Posted by JustSports
    This is now happening to me
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,866
    me too
    Apr 2007
    Nr Blackpool
    93
    And me, bloody hot weather! nothing a bit of a slam didn't sort out though.
    "I don't want to be a product of my environment, I want my environment to be a product of me."
    1999 Rocketship Silver S3 - Full Black Heated Leather, Bose, Armrest, Parking Sensors, Cruise Control, Sunroof, Dension Ipod Kit, Trakker.
    18" RSTT's with Eagle F1's,15mm & 10mm H&R Spacers, MTM Remap, FMIC, Milltek System & Cat, Silcone Hoses, Forge DV, Uprated Clutch, Cupra R Splitter, Tints, plus some I've probably forgot and more to come.......
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,866
    Something else to blame on global warming
