AH FabricationsChris Nott
    imported_Stewart
    How to bleed using VAG-COM?
    Can anyone please tell me how to use the brake bleeding procedure in VAG-COM?
    Many thanks!
    PaulS3's Avatar
    UK
    988
    Re: How to bleed using VAG-COM?
    never done t, dont like playing with brakes much.
    here is ross-techs page on the matter,
    http://www.ross-tech.com/vag-com/cars/absbleeding.html
    imported_Stewart
    Thanks for that Paul!
    Hmm, using version 303, i cant seem to access the output tests...
    Do i need to log in first? If so, where do i get the code?
    PaulS3's Avatar
    UK
    988
    303 is an old old version.
    are you on shareware version of vagcom?
    if so that could be the issue. some features are withheld from the free versions.
    my oem ross tech lead is on 512-4
