Volks AutosMonster Motorsport
Thread: cup holder
    Feb 2006
    London
    132
    cup holder
    Hello all,
    My S3 cup holder has jammed shut (old spillage probably) and won't dudge at all. Does anyone know how to go about dismantling the console so i can get to it? I have SATNAV fitted below so don't really want to disturb that lot. I'm thinking maybe through the dash vents above the holder/hazard/ESP switches would be an access point but unsure how to remove these also.
    Thanks [img]/ubbthreads/images/graemlins/book.gif[/img]
    Middlesex
    141
    Re: cup holder
    This thread had a guide on removing the vents. Id have thought itd be easier though to pull the satnav out and reach up from there, you wouldnt need to unhook anything just pull it out far enough to allow you to reach up behind the cup holder.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: cup holder
    I was under the impression that u could prise/tease it out?
    Have you tried a flat blade? Just remeber to protect the surround with a cloth.
    amb276s3's Avatar
    bird spotter
    Sep 2004
    Lincoln UK
    292
    Re: cup holder
    If you push hard on it and move up and down with your finger while still pressing this should be enough to free it off
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Re: cup holder
    Mine has stuck once as well, i was able to freee it by tapping it repeatedly in the middle for about 5 minutes and moving it up and down.
    hope it helps
    Mike
