EM TuningVolks Autos
Thread: Airbag problem
    Triple_A's Avatar
    May 2004
    Turku, Finland
    99
    Airbag problem
    There is Airbag-warning light in my dashboard and i looked fault messages with vag-com and there was:
    1 Fault Found:
    01218 - Side Airbag Igniter: Passenger Side (N200)
    32-10 - Resistance too High - Intermittent
    Then i removed seat and looked those seat wiring and those all seems ok.
    What could be problem?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,844
    Re: Airbag problem
    Usually a loose connection, have you reset the fault to see if it comes on again?
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: Airbag problem
    sounds like the connector under the seat indeed, remember that you will also have to clear the error with vagcom - not by just correcting the problem as the light wont go out until it is cleared.
