Badger5JMB Retrofits
Results 1 to 7 of 7
Thread: slow tickover
    hamski's Avatar
    Sep 2005
    UK
    116
    slow tickover
    My S3 (2002 BAM) has suddenly slowed its tickover to about 700 rpm. It intermittently spluts as though it's going to cut out.
    Does any one have any ideas re what could be the problem? Can it be adjusted?
    78
    Re: slow tickover
    I had the same problem when I changed my flywheel
    You can increase the revs with vagcom
    Simon
    MRCtuned
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: slow tickover
    Low revs and spluttering can be a vacuum leak. There is a hose to the left of the head that splits on the S3. Worth a look.
    Also dodgy coilpacks, lambda probes etc.
    Deffo need to have a look to see if there are any error codes.
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: slow tickover
    Thanks. I knew you guys wouldn't let me down.
    Now - who's got Vagcom? Need help..will travel
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: slow tickover
    Where abouts are you?
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: slow tickover
    Bristol [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: slow tickover
    A bit out of my area then [img]/ubbthreads/images/graemlins/frown.gif[/img]
