Sky InsuranceAH Fabrications
    Mar 2006
    Leicester
    95
    Switchable REVO settings?
    Got a REVO remap and SPS3 switch.
    Any reason NOT to run at high boost 9 all the time? Does it strain anything? Fuel consumption?
    If I didn't have the switch surely it would be permanently set at the highest setting anyway?
    Jul 2005
    2,488
    Re: Switchable REVO settings?
    only reason not to run it at 9,9 all the time is when your using crappy petrol, or on a really hot day.
    I'm not too sure i'd run it 100% like that without a FMIC either - but i'm paranoid as hell.
    imported_gek
    I run mine low boost 9, timing 6 on optimax.
    I thought this was the safest for everyday driving.
    I don't think I would ever go near high boost 9.
    Feb 2004
    UK
    1,320
    use vag-com to log timing ,boost and intake and adjust accordingly
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    925
    I agree with Ryan,that is what i did,i only run high boost 6 and timing 6 (old sps3).I also have a lot of mods inc huge high flowing fmic,higher settings without a fmic is pointless too much heat build up means ecu will pull back. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]Andy
    imported_Stewart
    Slightly off topic, what does 'pull back' feel like?
    At higher speeds (high torque scenarios), lets say between 90 and 100 mph, I get what I can only describe as a massive flat spot..
    For example, can be cruising at 90-100 and put my foot flat to the floor and its like the timing is massively retarded and it kinda 'bogs down' then all of a sudden it will pick up and accelerate...
    I have the Samco TIP and A Forge DV so can only assume its ECU related?
