AH FabricationsEM Tuning
Results 1 to 8 of 8
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    S3 clock fascias + needles into an A3?
    Right I've got hold of an S3 Speedo and a load of other bits cheap. So I'm up for having a go at transplanting the fascias and needles onto my A3 Speedo.
    Has anyone done this before?
    Mine currently has the non digital clock where as the new Speedo has a digital one. Could I just swap the rev counter over?
    Cheers Mark.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Re: S3 clock fascias + needles into an A3?
    Does that mean you will have the DIS bit spare Mark? If so, is this part transplantable(sp?)??
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    [ QUOTE ]
    [/ QUOTE ]
    Yeah got the DIS Spare. Came off a W Plate car.
    Mo-S3's Avatar
    North West
    703
    Yes it can be done, You will need to pull the needles off and simply remove the plastic dials.
    The needles do need a very firm pull to get them off and be very careful putting them back on making sure that they are back on zero.
    Also make sure that the redline on the rev counter is the same as yours. Which i doubt it will be.
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    [ QUOTE ]
    [/ QUOTE ]
    Cool.
    Have you done this yourself?
    Isn't the illumination different also?
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Just taken it apart the Rev Counter and DIS are part of the circuit board so no swaps.
    What about the illumination colour though?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    They are surface mount leds like the type found in mobile phones. If you are good with a small soldering iron you can swap them otherwise the needles will illuminate red like the original items.
    Mo-S3's Avatar
    North West
    703
    Dont even think about changing the SMT leds, the immobiliser is part of the circuits on the pcb and you will risk destroying they whole unit by trying to solder them.
