Volks AutosAH Fabrications
    Bolton
    94
    Idle control valve
    Does anyone know where it is on the S3???? I want to check it and give it a clean out.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Idle control valve
    There is no separate idle control valve to speak of. The idle is controlled by the electrobic throttle body.
    Bolton
    94
    Thanks, I thought it would have had a seperate one.
    I wanted to clean it out because of the problem i am having with startup. (car is nearly cutting out when I come to start it first thing in the morn)
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I would check to see if you have the updated coolant temp sender. This would be my first port of call.
    Bolton
    94
    HTC,
    How do I check for that???
    Car is 2001
    210 BHP
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
