Sky InsuranceChris Nott
Results 1 to 13 of 13
    Feb 2006
    uk
    12
    Lost boost on S3
    Pulled away from a junction fairly quickly this evening. The boost came on and then suddenly dropped off. There is virtually no boost at any throttle level. I didn't notice any significant smoke out the back at the time and there is no smoke now when driving. The car has a decent level of oil and water. I can't see any boost pipes off but then it is very difficult to see properly without decent investigation. Any thoughts would be very handy.
    Many thanks
    Mar 2006
    london/ essex
    114
    Re: Lost boost on S3
    dump valve leaking or acutuator or possible a split pipe.
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    I've experienced a similar situation as your self, but my boost eventually came back on. The car seemed to jump in hesitation and then rpms just drop. Sorry for not being very helpful [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Mar 2006
    london/ essex
    114
    have you guys got your esp on as if your trying to pull away quickly it doesnt like it and cuts the power.
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    LOL, hummm, to be honest I don't think i was pulling away enough for it to slip, as the turbo kicks in at around 3000rpms it suddenly drops off. But I just think it was a one off for me, haven' had it since that day (pretty sure the esp never kicked in)
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    Maybe you're blown a pipe off.
    I've blown my intercooler pipe off when doing extreme launches before.
    Mar 2006
    london/ essex
    114
    from stand still at a jubction or a roundabout if you give it enough then you can get it to kick in and the engine cuts its power right down and a yellow/orange tringle with! in the middle flashes until it sorts it selfout.
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    isn't that the ESP kickin in?
    Apr 2006
    sc
    6
    when the esp is active or operating it will flash as far as the boost check all hoses through the whole induction system also the reserculation valve could be stuck open and may just keep reseculating the air im not sure if your problem is a symptom of that. check the waste gate as well the oly time you will see smoke is if you loose boost that the ecu has seen and added fuel for. good luck
    imported_monkeytrousers
    I get this sometimes when I boot it in first gear, but it doesn't happen every time and never in higher gears.
    I'm sure it is the traction control, but interestingly the dash light does not always flicker when it happens.
    Feb 2006
    uk
    12
    Hi Guys
    Thanks for all of your replies. Took the car out later on in the evening after it had cooled down for a coupla hours and the problem had gone. Very strange. Lets hope it stays that way.
    Sam
    It's all in bits
    Apr 2006
    Bristol
    219
    I had much the same problem, it seemed to come and go to start with, but gradually got worse.
    Turned out it was the air mass monitor which are apparently prone to breaking.
    Apr 2006
    sc
    6
    cheeseman are you sure you didn't over boost for whatever reason and the car go into limphome mode.
